Ac problems
Old May 29, 2012 | 06:42 AM
doug holt's Avatar
You can take plug off low pressure switch and ground blue with white tracer to fender of truck and compressor will kick on is the ac cycling switch the one with little copper tube that goes into line
Old May 29, 2012 | 07:39 AM
RuralCruiser007's Avatar
Originally Posted by doug holt
Yesterday when I vacuumed down the system I only opened lowside I didn't open high side should I redo pull freon out and then vacuum down both sides of system after I figure out why compressor isn't kicking on thank you again
With this being a closed system and you pulling down the low side, the high side will have been done at the same time. The biggest thing is to draw the system down to 29.9 inches/mercury of vacuum for at least 15 minutes(I prefer for at least 30 minutes). This causes any moisture in the system to be drawn out.
The pressures you gave, were they when you jumped the low pressure switch? This sounds more like an electrical issue than a freon/mechanical issue.
HTH
Old May 29, 2012 | 11:23 AM
sounds like you just diagnosed the problem - bad cycling switch.
Sent from my Paranoid Android HD2 using Tapatalk 2.
Old May 29, 2012 | 04:55 PM
Vacuum on either high or low side does not matter. The system is open to both side when not running.
Maybe your Max A/C switch inside the truck in bad...not feeding power to the compressor?
Old May 30, 2012 | 10:54 AM
doug holt's Avatar
Well fixed the problem you know how it is when you do everything but look behind the dash thank you for mentioning maybe fan switch could not be sending power problem solve black wire with red tracer was unplugged off back off ac control
Old May 30, 2012 | 12:18 PM
97catintenn's Avatar
Is the a/c wire still hooked up in the back in the heater/ac controls in the cab? It's easy to miss because it is just a single wire and not part of the main wire harness that plugs into the back.
Old May 31, 2012 | 02:21 PM
Oops, sorry Doug. I wasn't being smart with you. I didn't realize this thread went on to two pages.
Totally missed that!
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
olgraybeard
Mar 24, 2003 06:32 AM
Dwight
Mar 18, 2003 08:14 PM
