93 vent window seal
Received 1,637 Likes
The older trucks have a differently designed seal. Its shaped the same, but the folds are different.
They will work with some modification.
I think I bought mine on eBay
You can't buy the seals for the 87 to 93 trucks. The earlier ones can be made to work but they leave much to be desired in my opinion. The best solution I can come up with at this point is to replace the the entire vent window assembly with ones from an 81 to 86 truck or Ram Charger and buy the seals for them.
N. Besonderes (05-02-2019)
How much different are the windows,any fitment issue on those?
QUOTE=Angry Johnny;3360260]You can't buy the seals for the 87 to 93 trucks. The earlier ones can be made to work but they leave much to be desired in my opinion. The best solution I can come up with at this point is to replace the the entire vent window assembly with ones from an 81 to 86 truck or Ram Charger and buy the seals for them.[/QUOTE]
Ended up getting seals. If you really need them, you can probably make them work, but it requires you to cut parts of the seal to make it fit the later year dodges. I ended up putting my old ones back on
97catintenn
08-07-2009 08:23 PM
Cowboy45
11-26-2006 11:08 PM
