'91s Intercooled or not?
Old Apr 25, 2006 | 05:23 AM
DanMan's Avatar
I've been browsing ebay to see what there is for nice 1st gen CTDs. There a couple nice '91s on there, one is intercooled and the other is not. Which one is right? Or are they both right, did the intercooled ones come out in '91 1/2?
Old Apr 25, 2006 | 05:52 AM
G1625S's Avatar
''Or are they both right, did the intercooled ones come out in '91 1/2?''
Bingo. Could be either/or in 91. They're both gonna be good trucks, and you can always add an IC in the future if you find a sweet non IC truck. Good luck in your search!
Welcome to DTR!
greg
Old Apr 25, 2006 | 07:50 AM
flashgordon's Avatar
I would personly go with the 91 1/2 intercooled truck if i had the choise,becuse you have to fab your own system, theres no system the will bolt on.....With that said, i have a 91.0 non intercooled and I love it!!!!
Old Apr 25, 2006 | 05:16 PM
DanMan's Avatar
Was there any hp diff between the i/c and non-i/c ones? If so, how much?
Also, in all the 1st gen CTDs, was there a hp diff between the auto and stds?
Thanks for the replys!
Old Apr 29, 2006 | 12:14 AM
Bill Tomlinson's Avatar
The non ic's have the 18.5 cm exhaust housing and much larger injectors. They are easier to turn up but you have to watch exhaust temps when towing much more carefully than the ic'd trucks. I would buy a 92 that was dead stock just because it is likely to have less wear due to the 21 cm housing and the small injectors and intercooling. It's head is slightly more robust than the older trucks. Turning up the later models requires an injector change that is not required on the pre 91.5's. So it is kinda up to you......
Old Apr 29, 2006 | 01:03 AM
bgilbert's Avatar
Dan, all 1st gens 89-93 auto and manual are 160hp 400ftlb.
Old Apr 29, 2006 | 02:44 AM
jeepsuck's Avatar
i thought you could just steal the parts from an IC junker and slap em on the non-IC? am i wrong?
Old Apr 29, 2006 | 12:37 PM
bgilbert's Avatar
There's more to it than slapping em on. The intercooler part is not bolt up. The other small parts though are bolt up.
Old Apr 30, 2006 | 02:31 AM
As far as part # go the a/c condencer,compressor and a/c lines are all diff between the non and intercooled (91)
1985cucv
Jun 12, 2009 09:50 PM
bigblue70
May 29, 2009 08:39 PM
440727
Oct 30, 2008 07:14 PM
wannadiesel
Mar 31, 2008 10:11 PM
sammy340
Apr 5, 2005 03:55 PM
