727 tranny ideas?
727 tranny ideas?
So should i keep the trany as is? Or do sumthin to it or upgrade to a stick or what do you guys think? Cause i might mod my truck out a little bit more with a little bit bigger turbo and injectors with a little more pump tuning but for right now its holdin up great. And about a month ago i changed the fluid over to synthetic in the trany and there was no metal or anything like that bad coming out of the pan. So help me out with some ideas or advice. Thanx
Torque converter (to get the power to the ground) and a shift kit or valve body to keep the trans from slipping.
As long as your primary use for the truck isn't high speed highway cruising, the lack of OD is not a big deal.
