727 Tranny help
Old Jul 3, 2008 | 05:45 PM
Bigdogbandal's Avatar
I had a 85 chevy diesel with a 6.2 for a while. It had a 700r4 in it and I found out that the 700 is dollars it costs to rebuild and the 4 is how many times a year I had to rebuild it. I'm betting you didn't get the torque converter onto the third stage and ate it up when you started it.
Old Jul 4, 2008 | 12:29 AM
700R4 could'nt live behind a 305 tbi v8. and there not cheap to beef up. go with the 4L80E. its a th400 bulletproof trans with a overdrive. good trans.
Old Jul 4, 2008 | 07:38 AM
Mcmopar's Avatar
I would drop the tranny and see if you did shear the lugs on the pump, these are not to hard to rebuild, and the pump is even easier.
Old Jul 4, 2008 | 08:45 AM
dieselJon's Avatar
So which is it? The TC or the tranny??? I thought the TC did all the pumping, then again, I have been wrong before..
Old Jul 4, 2008 | 08:51 AM
dieselJon's Avatar
Also, where do I get the parts to rebuild it?
Old Sep 8, 2009 | 07:49 PM
Mcmopar's Avatar
Did you rebuild the VB yourself?
Old Sep 9, 2009 | 12:06 AM
dieseldawg604's Avatar
Originally Posted by dieselJon
txs, if that is the case, then how do I check it?
I put the TC on the shaft, pushed it as far back as possible, bolted the tranny to the engine, bolted the flexplate to the TC.
The linkages are fine and adjusted right.
I hope it is not the TC.
ANyone know where to get a good converter for under $500???
Jon
you spun the converter back and forth right?????
it made a few definite clunks right?????
crossy
Mar 15, 2008 11:35 AM
dandyalgleish
Sep 9, 2007 08:20 AM
Micaiahfied
Mar 3, 2007 08:45 AM
masterphreak
Mar 2, 2007 01:37 PM
007c
Dec 18, 2005 09:22 PM
