1992 w250 5.9 cummins
the alternator shows it is working, but thr amp needle is on the left side of center, a/c clutch does not engage speedometer stopped working. replaced the batt with one that has 900cc amps. please any one have a solution?
also where is the regulator rhe parts house says it is on fire wall dealer says in ault
thank you in advance
calvin65
calvin65
Both are wrong, the regulator is in the PCM down next to the battery.
Your problem sounds like crank sensor trouble. Check to make sure that the crank sensor is securely mounted and that the gap is approximately 0.050" using a brass or plastic feeler (matchbook cover folded over once works in a pinch). Then work your way up the wiring harness looking for chafed wires, especially around the front of the head.
Guest
Posts: n/a
also where is the regulator rhe parts house says it is on fire wall dealer says in ault thank you in advance
calvin65
calvin65
I'd guess you might have some bad grounds.
Truck For Sale 1992 W250 Cummins Turbo with Banks Exhaust
rgriesser
1st Gen All Products
Apr 22, 2015 08:44 AM
Truck For Sale 1992 Dodge Cummins Turbo Diesel W250 Extended Cab
nintytwo 5.9
Feb 7, 2015 07:06 AM
james1
Feb 7, 2008 01:13 PM
