wet floor board fix-pass side
found this last weekend and thought I would pass this along also. Been having issues with the pass side carpet getting wet and staying wet. I 1st thought it was the coolant, but it didn't have any smell. I also thought about the drain for the evaporator, but still couldn't find the problem. So I decided to lift the carpet up, dry the flooring, and crank the truck and let the AC run for a while. After sitting under the truck(while running-sucks) I was able to see the water drain out of the tube @ the firewall. What was happening, was as it ran out it would run under and back down the tube towards the firewall. There is a seal, but it was still getting around or through it and wetting the floor. Not sure if this part came with a drop hose from the factory, but mine was just the tube sticking through the wall about an 1". I found a 90° spark plug boot worked perfect. That had about a 1/2" ID that fit right over the tube, turning the boot straight down would force the water straight down and not back onto itself. Sorry to be long-winded, just want to help out. I also used a small hose clamp to lock it in place. Later,Chuck
just realized I posted this in the drive train area...should be in non-drive train...sorry about that.
mine gets soaked on the drivers side, but Its coming from the back of the cab... I stuffed a paper towel down there and it stopped it from coming forward when it rains, but I don't know where its coming from back there...
I too have a heater hose running from my AC drain, back to the frame, works great, 2 years now no problems. I had the wet passenger floor too.
Also I siliconed my 3rd brake light, it leaked something awful. I have a topper so I don't need it.
Do as Infidel suggests, turn the AC blower to high, use a squirt bottle full of dish soapy bubbles, spray 3rd tail light, blowing bubbles will show your leak.
When I did that I found two leaks, one on the 3rd taillight, the other in the upper corner of the rear sliding window. Resealed window, fixed that one too.
