Wet Floor board
Old May 8, 2012 | 09:13 PM
traverler48's Avatar
Wet Floor board
Over the last 16 years I have had to pull my seat and raise the carpet to dry with a fan twice because of the third light. Mind is a club cab and by removing the jack on the passenger side you can see the water trail or channel to the carpet. This happened recently while deciding if I wanted to by a new light or gasket again I needed some kind of fix as I did not want to go the RTV route. I noticed a obblong hole in the side behind the jack. I took a 2 foot bar with a flat sharp end and cut the metal at the bottom of the hole and channeled the water out through the weap holes at the bottom of the cab until I decided what to do. And then foward of the hole I took a tube of Dicor and a straw an built a small dam I don't think it was needed but!!!! THIS IS A TEMPORY FIX but has worked sofar until I have time to fix it properly. The truck has been sitting in the rain for 2 days and still dry.
About the light it looks like it is warped on the bottom probably from heat and I don't think a new gasket will fix it this time. I have found 2 at JC whitney one has to be wired to fit about $39.00 and the other one is plug and play $69.oo.
Old May 9, 2012 | 12:40 AM
joem's Avatar
I used the soft formable RV window sealent, its like a plumbers puddy, rolled it into the size i wanted, dropped it into the the grove on the light and tighten the 2 light screws a bit every hot day. Cab 100% dry now
Old May 9, 2012 | 07:49 AM
I have used the puddy tape on my RV's before it is good for a long time. I have some silicone puddy tape it is used for seams on steel buildings once you put it on its stuck.
Old May 9, 2012 | 07:59 PM
whiskers's Avatar
I had this problem for years on my '98. Someone on here told me to put a 90 degree elbow on the drain tube for the A/C on the firewall. A little silicone glue and a PVC fitting and no more wet floor board. The fan was blowing the condensate back into the cab instead of letting it run out the tube. Worth a look.
1985cucv
15
Jun 23, 2009 03:21 AM
benny852
Jan 28, 2008 11:30 PM
blazinchuck
Sep 4, 2007 04:58 PM
1ST CUMNZ
Dec 16, 2004 12:20 AM
Palmetto_kid
Jul 9, 2004 12:23 PM
