Overflow Valve question
Old Jul 10, 2006 | 11:04 AM
TxDiesel007's Avatar
Guys
i need a new overflow valve. Aside from the better (proper) fuel pressure, will i see any improvement with a new overflow valve? Ive changed it once already so i know how to change it, but i saw no gains. With a good OFV and proper pressure will i see any performance gains or feel anything on the truck?
Thanks!
Rick
Old Jul 10, 2006 | 11:09 AM
displacedtexan's Avatar
The guy that did the timing for me says that you can shim it (not sure how, as I have never messed with one) and net a few (30) horsepower. We talked about it for a little bit when we were talking about where to set my timing.
I should probally change mine. But truck parts cost money...
Old Jul 10, 2006 | 11:54 AM
infidel's Avatar
If you mean raising the pressure above factory specs you won't see any performance gains and may even see a decrease.
Old Jul 10, 2006 | 11:56 AM
Well I trust Infidel over the guy that did my timing. I trusted him to do the timing, based on the reccomendation of the local injection shop, but he is far from Bill in knowledge of these trucks.
Old Jul 10, 2006 | 12:00 PM
signature600's Avatar
If you've already changed OFV's once, and it's got low pressure again, check the Lift Pump, too! I know the OFV's have been known to go bad right away, but it's worth checking
Chris
Old Jul 10, 2006 | 12:03 PM
v8440's Avatar
How much does a lift pump cost for our trucks?
Old Jul 10, 2006 | 12:10 PM
infidel's Avatar
About $90 from a Case tractor dealer to about $200 from a Dodge dealer.
Cummins wants about $120
Old Jul 10, 2006 | 12:18 PM
Common's Avatar
Where is the lift pump located?
Old Jul 10, 2006 | 12:25 PM
Just above the starter...
Old Jul 10, 2006 | 07:25 PM
bmoeller's Avatar
That is where I got mine.
BobWatts
May 31, 2009 11:29 AM
ohanahorse
Sep 27, 2007 02:34 PM
schoust
Sep 24, 2006 09:32 PM
Chieftian
Jan 15, 2006 07:59 AM
turbo6justin
Jul 11, 2004 11:39 PM
