Another DA rookie question
Old Jul 10, 2006 | 06:49 PM
Freight_Train's Avatar
Does anyone know if the Front Cover for the 24Valve(Like in our Freightliner Rollback) will fit a 12Valve?If not,did anyone ever make a front cover for a Aircompressor equipped truck?Would love to simplify some onboard air like our Freightshaker has when I drop a Gen 2 12valve in my F350.
Old Jul 10, 2006 | 08:00 PM
infidel's Avatar
The stock Cummins air compressors I've seen take the place of the vacuum pump in the 5.9 application. Problem doing it on a Dodge is that there isn't enough room under the hood for the compressor.
Might be enough room with what you're doing though. If you need vacuum also then just use an electric Ford vacuum pump. They are under $100 and are longer lived than the mechanical Dodge vacuum pump.
Old Jul 10, 2006 | 08:22 PM
Thanks.That is good to know.The Cummins Swap keeps getting sweeter and sweeter.
Captain Coop
May 2, 2009 04:41 PM
Captain Coop
14
Feb 18, 2009 08:14 PM
checkob
May 21, 2008 06:06 AM
Heston_ram3500
Apr 16, 2007 10:33 PM
HotRodK
Feb 21, 2007 01:10 PM
