overflow valve question
Old Sep 25, 2007 | 11:10 AM
ohanahorse's Avatar
Hi, does anyone know how to reassemble the over flow valve (97 12 valve). I took it apart to clean it and when I 'carefully" tipped it over, it all came tumbling out. I have two washers, a tapered spring and a ball. My guess is ball first, washers, then spring with taper pointing away from ball???
thanks,
Old Sep 25, 2007 | 01:10 PM
wcbcruzer's Avatar
There is also a small washer that goes between the pointy bolt and spring. I lost that one when I was putting mine back together. Sorry, I forgot exactly how everything goes back together though.
Old Sep 27, 2007 | 02:34 PM
TxDiesel007's Avatar
thanks,
Negative..
ball goes on the bottom, then the tapered washer wehre the little ball sits, then the two little washers, the spring, then the 13 mm top of the OFV...
Rick
BobWatts
May 31, 2009 11:29 AM
schoust
Sep 24, 2006 09:32 PM
TxDiesel007
Jul 10, 2006 07:25 PM
Chieftian
Jan 15, 2006 07:59 AM
turbo6justin
Jul 11, 2004 11:39 PM
