over drive mechanicals
Is there a way to over ride the TPS and mechanically/electrically engage the overdrive when you want it?
If the problem is the tps, you don't have to jumper the overdrive solenoid. You can jumper the tps output to ground instead and solve the problem that way, at least for my model year. When I finally figured out my tps was at fault for my '94 not shifting into overdrive, I wired a switch in the cab to ground the tps signal output through a 1 kilohm resistor. The 1000 ohm resistor is a precaution to keep from grounding out the 5 volt reference that the PCM supplies to the potentiometer in the tps. I think it has about a 50k pot in there, and if the wiper is set all the way at the hot end, you don't wand to short that wiper to ground.
Grounding the tps output makes the computer think you have let off the throttle, and it will shift into overdrive.
Haynes manual has a diagram for the tps connector, but it gets the ground and reference pins reversed for the 47RH, I notice. At least the output (Haynes calls it "signal") is the middle wire, so you can't go wrong. Haynes also calls the 47RH a 37RH, and apparently has some other little mistakes like mixing up inch-pounds and foot-pounds.
Here's a good write up which might help you with what you want to do:
https://www.dieseltruckresource.com/...d.php?t=142641
https://www.dieseltruckresource.com/...ad.php?t=42003
TxDiesel007
02-18-2007 10:42 PM
Tank_66
18
12-31-2006 02:15 PM
