"Newbie" 95 12v starts but cuts out??
Old May 16, 2006 | 08:30 PM
12vbmm's Avatar
Question "Newbie" 95 12v starts but cuts out??
I have a 95 12v and I ran in a ditch with it and banged up the front pretty bad, engine is still fine but when I went to go start it, it will start up and run for a few seconds then cut out. Seems to be getting air in the system. TRied priming the system and get the same thing ???any help would be great.Am a Newbie
Old May 16, 2006 | 08:45 PM
dzlfarmboy's Avatar
It probably didn't help hittin that ditch and snapin a front axle!!!
Old May 16, 2006 | 09:57 PM
12vbmm's Avatar
well if i had not done that then i wouldnt have had no reason to make it buck nasty
Old May 17, 2006 | 09:12 AM
TxDiesel007's Avatar
Tried bumping up your idle?
That hit mighta loosened the little screw and nut and now u need to readjust it. it could also be your fuel shutdown soleniod is outta whack. just readjust it and u might be set..
Rick
Old May 17, 2006 | 11:29 AM
plow's Avatar
why would you type this? I really don't think he hit the ditch on purpose. I don't think he said anything about a front axle.
Old May 17, 2006 | 11:30 AM
plow's Avatar
And what is this? Do you two know each other?
Old May 17, 2006 | 11:34 AM
turbo thom's Avatar
Probably riding together.
Old May 17, 2006 | 02:11 PM
12vbmm's Avatar
we know each other hes my good friend and isperration in geting in to the world of diesel power.lol we are just hard on each other.
Old May 17, 2006 | 03:40 PM
dzlfarmboy's Avatar
I was just playin with him he's my friend down the road and i been tryin to figure this problem out myself with him. I just got him registered on here so he can learn some stuff like i have done.
Old May 17, 2006 | 03:46 PM
dzlfarmboy's Avatar
overflow valve
Any of you all think it could be the overflow valve not working and making the pump not keep up enough pressure causing air in the system? And making it cut out.
He can get it to start but when he tries to give it throttle it will just sputter and cut out.
dodge-dodge
Apr 3, 2010 10:24 AM
97catintenn
Jan 7, 2010 11:33 PM
NDanecker
14
Oct 31, 2008 08:37 PM
Stamey
17
Jul 30, 2007 08:08 PM
JKM
Jun 29, 2004 11:12 PM
