Lift pump
Lift pump
Can anyone tell me if this is the right lift pump for my truck?
http://secure.ssbtractor.com/cgi-bin...oduct=INFLP43C
This is what I have saved in my P/N file, not the same number, but I do believe Infidel and others have use the pump you show.
I would try it for that price.
Here are the numbers I have listed, Lift Pump 3925709 has been replaced by a new design PN 3936316
Just paid more than that ($100 shipped) for a Cummins pump and it was made in China to boot! Can't win I suppose. I would go with a Cummins or a Carter pump. I replaced one Saturday after the spring inside broke a coil off. Good Luck. I would rather do another headgasket than the lift pump again.
When you remove the lift pump, along with it will come the fuel heater. Trying to put the two together, fighting the spring in the lift pump while getting the bolt to start in a really cramped space is next to impossible. Don't even try. Replace the bolts with studs and nuts and all your troubles will be over.
Yukon Dodge
18
Jul 1, 2004 10:08 AM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
