Dexron III/Mercon for ATS Stage IV?
Old Jun 24, 2011 | 05:00 PM
Robert Rausch's Avatar
I've always changed my own trans fluid. I've got 10 years (168,000 miles) on my ATS Stage IV rebuild in my '95, 2500, and I've been using ATF +4. However I can't find enough of it to do a full change and I was wondering if anyone with an ATS trans here has used Dexron III Mercon fluid?
Old Jun 24, 2011 | 07:46 PM
John_P's Avatar
Robert, as I recall, Clint told me to stick with the ATF-4 but I hear what you are saying on it being hard to get. It is pretty expensive now too. Let me know what you find out.
John_P
Old Jun 24, 2011 | 07:52 PM
I did call ATS and talked to a tech guy. He said I could use the Dexron III Mercon with no problem. And I called Bellflower Trans--they are an ATS shop in Bellflower, Cal., and they said the same thing. So I guess I'll give it a try.
The problem was I couldn't find the ATF +4 in gallons. Buying it by the quart, when I need 14 quarts or so just makes it more expensive than it should be.
Old Jun 25, 2011 | 06:36 AM
13FOX's Avatar
Add a bottle of Red Lube Guard to that Dextron III.
Old Jun 25, 2011 | 10:10 AM
Thanks Fox. I'll get some and add it.
Old Jun 25, 2011 | 08:30 PM
John_P's Avatar
Thanks Robert!!
Old Jun 25, 2011 | 09:52 PM
John, do you remember how much the ATS takes? I always drain the TC, and with the MagHytec pan, I remember it takes a lot, but I just guessed about it holding 14 quarts.
Old Jun 25, 2011 | 09:57 PM
John_P's Avatar
Mine holds right at 20 quarts Robert with the TC and all drained.
Old Jun 25, 2011 | 10:20 PM
Do you have the double deep pan or the regular Mag Hytec pan?
Old Jun 26, 2011 | 08:52 AM
John_P's Avatar
Robert, I have the double deep pan on both of my trucks.
Old Jun 26, 2011 | 04:28 PM
How much red LubeGuard should I add? I couldn't find it locally and ended up ordering a quart of it.
Old Jun 26, 2011 | 07:05 PM
John_P's Avatar
Robert, when I used LubeGuard I always added the whole bottle and then adjusted the ATF accordingly.
Old Jun 26, 2011 | 08:57 PM
esde's Avatar
Dave Goerend recommended Dextron mercon 3 with a napa additive. No problems this far.
Old Jun 28, 2011 | 09:58 AM
infidel's Avatar
Start out with no LubeGard.
If the shifts are too jerky (I call it crisp) for you add about 6 oz of LubeGard at a time till the shifts are mushy enough for you.
I've always used the LubeGard Black.
Old Jun 28, 2011 | 03:12 PM
Thanks Bill. I have straight Dexron III/Mercon in it right now. But I'm going to add a bit of the LubeGuard-I'll do 6 oz and see what happens.
sherod
May 10, 2014 06:44 PM
Jim Lane
Mar 28, 2012 03:39 PM
royta
Mar 11, 2010 08:03 AM
large_marge
Feb 17, 2005 05:09 PM
DEC
Sep 26, 2003 08:29 PM
