Dexron II or III?
Old Jan 11, 2012 | 12:38 PM
Jim Lane's Avatar
Dexron II or III?
What type of transmission fluid does my A-727 take?
Dexron II or Dexron III I just need to top it off.
Thanks in advance.
Jim
Old Jan 11, 2012 | 01:22 PM
Blowndodge's Avatar
My book say Dexron III
Old Jan 11, 2012 | 05:31 PM
MARF75's Avatar
Just pull it apart and Jim Lane it. Then you could probably use H2O or whatever's handy.
If you don't know then no one does!
Old Jan 11, 2012 | 05:37 PM
carl48's Avatar
use the atf4+
Old Jan 11, 2012 | 09:03 PM
ATF+4 or
I am pretty sure Dexron is a big no-no in chrysler trannies?
Old Jan 11, 2012 | 09:29 PM
Jim Lane's Avatar
Interesting..
It says Dexron II right on the dipstick but after I had it rebuilt last time I wasn't sure if he said to use II or III but I know he said Do NOT use Ford ATF.
My trans started to slip a bit this morning but only until it warmed up, I think I am going to drop the pan and hope the magnet is clean and then replace the filter.
Thanks Jim
Old Jan 11, 2012 | 10:18 PM
torquefan's Avatar
As far as I know, everything that originally called for Dexron II was ok for Dex III when it superceded II.
Old Jan 12, 2012 | 09:00 AM
apwatson50's Avatar
I am not aware of dex II being available anymore. Pretty sure Dex III replaced it. I have been using dex III in 2 different A518 trannies for several thousand miles. So far no issues.
The reason is that it is much cheaper fluid then ATF+3 or +4.
Old Jan 12, 2012 | 09:23 AM
Greed 93's Avatar
You need to use dex 3 i have built many 727 transmissions if it is factory the clutchs do not like plus 4 Also if you want a little bit of a harder shift and works better for towing you can use type f .
Old Jan 12, 2012 | 10:45 AM
sootnsmoke's Avatar
I looked at the couple receipts I had from the trans shop that rebuilt the trans in our 91 a few years ago. The trans shop used ATF +3.
Of course, all I find in the stores is +4 since I believe it superceded +3.
My original 91 manual specifies MOPAR plus fluid but states Dex II can be used if + fluid is not available.
Old Jan 14, 2012 | 01:34 AM
pjc360's Avatar
type f
Old Jan 14, 2012 | 01:50 PM
Trooperthorn's Avatar
Wow! Jim you opened up a can of worms with that one. ...lets see...II, III, +3, +4, F, h2o...
I guess I will chime in with sawdust and banana peels...oldschool.
Old Jan 14, 2012 | 02:08 PM
MARF75's Avatar
I like that idea! It's time for a flush so I'll try that sawdust ,banana thing
Old Jan 14, 2012 | 05:47 PM
pjc360's Avatar
type f works well in the 727s trust me
Old Jan 14, 2012 | 05:48 PM
pjc360's Avatar
i wanna run type f in my A-518 but i am trying to determine if running type f in the A-518 would be an y different then running it in the 727.
only differences i can see is the A-518 having the overdrive unit, other then that they are basically the same transmission.
