ATF dexron II or III for '93 w/DTT
Old Feb 13, 2005 | 04:23 PM
large_marge's Avatar
i've sprouted a tranny fluid leak and upon refilling i see that the dip stick says to use dexron II. however, it's a DTT hybrid tranny with some '96 guts in it. also, i have a gallon of dexron III in my hand. so can i use the III or should i go get some II?
thanks
jeremiah
Old Feb 13, 2005 | 04:40 PM
dzpoorjr's Avatar
Probably has the dextron 3 in there! Get you some lubegard to add to it also-good stuff! Although Chrysler still recommends ATF-3 or 4!
Old Feb 13, 2005 | 04:45 PM
thanks
Old Feb 13, 2005 | 06:56 PM
infidel's Avatar
Can you even get Dex II anymore?
Old Feb 17, 2005 | 05:09 PM
COLDHEART's Avatar
Once they change out the guts you can use dexIII no problem.I called my trans shop to ask and that is what they put in.Hope this helps.<><
sherod
May 10, 2014 06:44 PM
Jim Lane
Mar 28, 2012 03:39 PM
Robert Rausch
14
Jun 28, 2011 03:12 PM
royta
Mar 11, 2010 08:03 AM
DEC
Sep 26, 2003 08:29 PM
