Adding Horsepower
Old Jun 7, 2014 | 08:03 AM
Sonofgrace's Avatar
Adding Horsepower
I have a 95 Ram 3500 4x4 auto 12v cummins bone stock. I would like to add a little horse power without spending money or as little money as possible- I'm not needing/wanting HP so bad as to spend $$$. I've heard that all I have to do is "crank it up a little" and that doesn't require a mechanic to do it..... I've actually heard numerous different things like "shifting the plate forward"....
At 160 stock HP, going into inclines pulling a load, with plans to increase my load as soon as business picks up (Lord willing), I'd like to not get passed by 4banger ford rangers...
If there is a simple and inexpensive way to do this I'd like to.
Any ideas?
Old Jun 7, 2014 | 08:44 AM
Just like you said, slide the fuel plate forward, is one of the free mods.
Or adjusting the waste gate on your turbo, to give you more boost.
I would buy and install a EGT pyro and boost gauge BEFORE I started tuning a truck I tow with.
I am half way through installing those two gauges on my '95 I tow with mostly, BEFORE I do any HP adding mods.
Old Jun 7, 2014 | 03:57 PM
patdaly's Avatar
And start saving immediately for a built trans......... Or get a good VB and Converter in before you kill you trans.
Old Jun 7, 2014 | 09:01 PM
Sonofgrace's Avatar
patdaly, I also was told exactly what you just said to me. What is a "VB"?
Old Jun 8, 2014 | 01:01 PM
patdaly's Avatar
Valve Body
Old Jun 19, 2014 | 10:40 PM
1workinman's Avatar
power
Any ideas?
I to have a 95 4x4 with 3.54 or what ever they or not 4.10 . First I will tell you what I have done with stock transmission which is still working . I did give me one problem a thousand miles ago but not since. The only thing that I have done to it that gave me more power and better mileage is timing. That's it . The rest gave more power. A number 10 fuel plate all the way forward. 3 k governor kit. 215 injectors . Bigger air cleaner,less restrictive exhaust. Blocked waste gate. Makes 32 or so boost. That was done 150 k miles ago on a stock transmission . Timing is 17 degrees . Yes I can blow throw the stock convertor at ease. I have band aid the transmission but it is still working and all I do is tow. I know what worked for me. My mileage went from 16 to 21 or better . That's at 65 with the ac. I no long worry about the automatic breaking as it will at some point. Good luck Jim
Old Jun 20, 2014 | 06:26 AM
jughead's Avatar
my opinion only but only weak link in diesel trans is that sloppy converter. builds way to much heat doesnt put power on the ground
Old Jun 23, 2014 | 08:02 PM
1workinman's Avatar
Yea that true , in fluid coupling . But it probably easer on the drive train . Spools the turbo , less torque to the clutches. Or that is what I was told. Even worse in reverse . Reverse is pretty high gearing , I use low , low 4x4 while reverse with a trailer when loaded , to help control heat and torque to clutches . Jim
Kimmed
May 25, 2004 10:54 AM
BEHRMAN
Apr 3, 2003 05:02 PM
DieselDaze
Jan 2, 2003 09:04 AM
Hummin Cummins
Dec 2, 2002 09:51 AM
gitchesum
Oct 28, 2002 01:15 PM
