Fuel level unit
Old Jun 23, 2014 | 01:17 PM
meroma2's Avatar
Fuel level unit
Anyone know where I can purchase a new or used certified Fuel Level Unit
Part #4864209.
I have been told part is obsolete & aftermarket is available.
I found a used one for $250.00
Where can I get a new or used one for cheaper ?
Thx Mike...
Old Jun 23, 2014 | 05:11 PM
patdaly's Avatar
What you show is the whole module, typically you don't need to replace. Dodge used to have remanufactured units for under a hundred, but unless your tubes were rusted away, you only need a sender.
Unfortunately, looking at the parts manual, the 94-96 trucks had either a Carter or a Walbro, and there is a different part number for either.
Are you trying to fix your fuel gauge or fix rotted lines coming out of the module?
Old Jun 24, 2014 | 07:39 AM
meroma2's Avatar
Thx PD,
I'm replacing fuel lines & the 90 degree fittings coming out of the top of the module for the supply & return r broke in half
Old Jun 24, 2014 | 08:42 AM
patdaly's Avatar
Originally Posted by meroma2
Thx PD,
Ah!
Easy cheesy, you could go with the plastic garbage from the later trucks, or Larry B has just what the doctor ordered, never again will you worry!
http://www.fostertruck.com/larryb-s-...1984-2004.html
Old Jun 24, 2014 | 09:58 AM
meroma2's Avatar
Thx P
I found these also, might want to pass on to other lost souls.
www.tristarrradiator.com 1452 State Rt 89 Seneca falls,
NY13148
sendingunitguy@gmail.com
Old Jun 24, 2014 | 04:39 PM
patdaly's Avatar
Cool! Always like to have another solution...... I have it bookmarked now.
mhuppertz
May 4, 2011 09:47 PM
ohanahorse
Apr 8, 2011 06:22 PM
Duallydog
Mar 12, 2009 10:54 PM
Opacity
Jan 15, 2008 09:08 PM
TJE
Oct 23, 2007 08:01 AM
