3K GSK RPM Governor Spring Kit 94-98 Dodge 12V Cummins
Instructions should come with the unit...
Here is a link to some help...
PEAK GSK install instructions
sweet thanks . i may buy a 50hp kit . just wake her up a bit ... i want to keep mileage so i don't want to throw much at it ... but put 3000rpm spring ,fuel plate , and 50hp injectors , but thats a few months away
A GSK is probably the best initial mod for an auto truck. BEWARE, it may burn out your converter lock-up clutch especially if you change plates or plate setting. The engine will rev a lot higher, but the transmission will still shift per the valve body.
The instructions are OK except for a some fine details.
Start with the plate change instructions for dealing with the break-off screw on the AFC housing.
Cut all the lock wire on the pump screws and discard.
It is much easier to remove the lever (linkage) on the fuel shutdown to access the governor spring plug. Do not loose the small half moon key on the shaft.
The stock spring seat is 2 pieces. Remove 2 pieces with your magnet.
You remove 3 springs and only install 2 springs for a 3k GSK.
Not all stock pumps have shims on the springs.
If the large outer spring (idle spring that is re-used) has a shim install it again. Any shims with the 3 inner springs are discarded
If the idle goes up (signifcantly) you need to loosen one or both spring set tension a click. Small change idle change (100 rpm or so) are done with the idle screw.
IMO 3K is plenty for the street, keep the little spring for the track where you may need the extra rpm to make it to the end.
mhuppertz
24
Oct 1, 2004 08:41 PM
