3200 RPM Governor Spring
Old Jun 6, 2005 | 12:30 PM
efbeason's Avatar
After cruising the site I saw some comments that said I could up my rpm's with a 3200 rpm spring and by grinding off something in the fuel pump. Anyone know where to get the 3200 rmp governor spring? Exactly what is it that you grind off in the fuel pump when you put the governor spring in? Any info would be greatly appreciated. Thanks!
Old Jun 6, 2005 | 01:11 PM
apwatson50's Avatar
PDR has the spring, or any bosch repair shop should have it. I believe the part numbers are in the tech faq section and some pretty good instructions on how to do it, and why.
Old Jun 6, 2005 | 01:19 PM
efbeason's Avatar
What is PDR? Is that a website?Store? Thanks!
Old Jun 6, 2005 | 01:30 PM
apwatson50's Avatar
Piers Diesel Research, They are a website/store/repair shop I believe.
Good place to shop.
http://www.piersdiesel.com/
Old Jun 6, 2005 | 01:44 PM
efbeason's Avatar
The governor spring (item #: PDR2613000 Governor Spring Kit 3000 RPM) on this site is $125.00. Anyone know of a place to pick one up cheaper?
Old Jun 6, 2005 | 01:48 PM
NeedMoPower's Avatar
That's a 300GSK for a 94-98 12 valve. A 3200 spring for our trucks will cost you around 15 dollars at your local pump shop.
Old Jun 6, 2005 | 01:57 PM
jiMMyCTD's Avatar
you have to call pdr, its not on their site!
Old Jun 6, 2005 | 02:06 PM
apwatson50's Avatar
Sorry, I forgot about that, they should really put it on their site!
Old Jun 6, 2005 | 02:17 PM
apwatson50's Avatar
I also got the throttle shaft bushing to put in when i'm in there, and the gasket and the spring and it all together was like $40.
Old Jun 6, 2005 | 04:27 PM
efbeason's Avatar
Thanks alot. I emailed PDR and the guy told me that the spring for the 1st generation trucks was $18. Thanks for the help!
Old Jun 6, 2005 | 05:24 PM
The AFC lever is circled in yellow. The red line points to the "foot" that gets ground off. Mine is ground so that the area where the foot was is now in line with the rest of the lever.
Just to clarify where to grind, you want to grind the surface (the back of the lever as it sits with the pump assembled) that the red line is pointing at, not the bottom of the lever.
Old Jun 6, 2005 | 10:21 PM
mhuppertz's Avatar
I put in the 3,200 a while back, but didn't know about grinding the AFC lever foot. What does this do? Is it worth taking the top back off my pump?
Mark
Old Jun 7, 2005 | 09:05 AM
efbeason's Avatar
When I get ready to do this mod, can I turn my idle speed down?
Old Jun 7, 2005 | 09:30 AM
pwrtripls1's Avatar
Mark
I want to know too. If it makes more power its got to be worth it.
Old Jun 7, 2005 | 05:54 PM
http://dens-site.net/Dodge_CTD/Gover..._Spring_24.jpg
A much better pic of the "foot". Thanks Den!
From an earlier post of mine:
I like the AFC lever mod better than turning the pump up to the edge of runaway. The reason the pump wants to run away is that you bias the control collar so far toward the "full fuel" position that there is no longer enough open port area in the "defuel" position to slow the engine down at high RPM due to internal pump pressure. If you're sitting there going "WTH does that mean?" you're not alone. Read on.
VE pump 101: The control collar controls injection duration (which controls the amount of fuel injected) by varying the amount of effective stroke the injection plunger has. The control collar covers a vent port in the plunger during the effective part of the stroke, as the plunger moves towards the back of the pump the vent port is uncovered, which bleeds off the pressure and stops injection. The longer the vent port is covered by the control collar, the more fuel the injectors get. The control collar position is determined by the governor and the governor spring. Basically, if you are asking for more RPM than the pump is making, the collar is pulled towards the full fuel position by the governor spring. Once the pump is making the RPM you have asked for, the governor balances against the governor spring and brings the control collar back towards the defuel position.
Cranking up the fuel screw moves the entire governor lever assembly but does not change the range of motion. When the fuel screw is too far in, there is no longer enough open port area in the new "defuel" position, flow is restricted so injection continues and engine RPM hangs or continues to rise. The shutoff lever will not help you here because it acts on the governor lever - which is already defueling as much as it can.
Modifying the AFC lever increases the travel of the governor lever towards full fuel but does not move the defuel position. So instead of moving the range of motion, you increase the range of motion in the full fuel direction. Clear as mud?
A simplified version:
Grinding the foot off the AFC lever increases the total travel of the governor lever. This allows you to make more power without turning the pump up and the problems that go along with it like runaways and not being able to get the idle slowed down. Turning the pump up only moves the governor arm further towards the full fuel position, it does not increase the range of motion. This is why you eventually reach the point of runaway if you keep turning the full fuel screw. The only time I would recommend NOT grinding the foot during a 3200 RPM spring install is if you live in a state where the truck has to pass a "snap test" for opacity.
Grinding off the foot is worth somewhere around 30 HP, and the torque that comes with that much extra HP.
