12 valve conversion
On edit, you don't mean the vacuum pump, do you? If so, there is an oil supply line from the block to feed the vacuum pump pressurized oil for lube. It dumps back into the engine thru the timing case.
that's what I was thinking it was but wasn't sure there is a braided oil line running to it so it that's so this steel fitting would have to go to whatever it runs correct ill see if I can get a pic I don't need to use it was just curious if I can block it off and not hurt anything
If you are getting rid of the pump, then you can plug it off at the block.
I don't need but but correct me if im wrong its still going to be turning regardless if im using it so I should keep the oil line hooked up and just block off the vacuum port im thinking
Yep, rubber cap will work just fine. There is a 4BT specific PS pump that has the gear on it you could swap and remove the vacuum pump totally, but they aren't real common, fleabay usually has 1.
DeerHunter812
Apr 30, 2026 08:52 PM
DeerHunter812
Mar 22, 2009 05:07 PM
dsljunkie
Jan 14, 2004 10:46 AM
