How to put a Cummins in a 1980 Crew Cab.
Old 04-29-2015, 09:32 AM
PowerWagonCC80's Avatar
I have a Crew cab and I'm wanting to put a 12V Cummins motor with a NV4500 married to it how can i do that, what need to be done.
Old 04-29-2015, 09:58 AM
RamGuy84's Avatar
Crewcab's are very simple . your best bet is to get a donor truck . That way you have all the wiring and all the small stuff . you will need to relocate the wiring bulkhead over some so the clutch pedal can be Mounted . Do a search on here .there have been Several done . Just Takes Time .
Old 04-29-2015, 12:46 PM
Received 2,392 Likes on 1,576 Posts
Trashingcows and many others here have detailed treads / write ups on this.
Grab a beer sit down and do some reading.
Old 04-29-2015, 02:02 PM
Received 1,332 Likes on 862 Posts
As Ramguy mentioned a donor is very helpful, but not completely necessary. Plenty of people have swapped in a cummins with no donor. You just won't have the cummins info center, automatic grid heaters, and a couple other functions. Just depends on how close to an original cummins 1st gen you want your truck to be.
On that thought, and this could effect your decision, you also need to decide if you are going with an intercooler or not? Lots of things to consider, and a detailed build thought out before you start will save you time and money down the road.
Old 05-05-2015, 09:27 AM
Where would I find the posts of guys putting the Cummins 12v in their trucks?
Old 05-05-2015, 11:37 AM
Here is my build thread....
https://www.dieseltruckresource.com/...update-305923/
There are plenty more on here...just search "crewcab Cummins" or "crew cab cummins" and start looking at what pops up.
Here's a couple more...
https://www.dieseltruckresource.com/...tarted-296686/
https://www.dieseltruckresource.com/...ew-cab-230012/
Old 05-05-2015, 11:19 PM
gyman98's Avatar
Mine should be in my signature
Old 05-06-2015, 06:38 AM
MARF75's Avatar
Thrashingcows and Gyman have 2 really good crew cab builds!
Old 05-06-2015, 10:44 PM
And a couple Canadians EH!!!
Old 05-07-2015, 08:12 AM
Received 1,637 Likes on 1,112 Posts
Whatever you do, dont listen to a single word Oliver Foster says. He doesnt have a clue regarding anything technical of these old Dodges
mknittle's Avatar
must be th long cold winters
Old 05-09-2015, 12:25 PM
In case this was not clear, I do believe NJTman was being sarcastic.
His sense of humor isn't normal.
That being said, there are a lot of people here with MUCH more technical knowledge/background than me.
I just wrench on 1st gen 12Vs and if I am lucky, my '85 crew cabs often.
I just don't post many pictures as I am a little special that way.
Old 05-09-2015, 10:39 PM
Yes you are....Now put your Helmet on and go to bed....
Old 05-10-2015, 07:52 AM
Normal ? Well, that's another thing you have not a clue about.....
Old 05-10-2015, 08:44 AM
mknittle's Avatar
What is normal? I don't know what that is.
Quick Reply: How to put a Cummins in a 1980 Crew Cab.
