fuel shutoff solenoid bracket bolt size
Old 04-13-2010, 08:09 PM
Dojman's Avatar
Guys, I am replacing my daughters (95 reg. cab 2wd) solenoid and bracket. The bolts that held her previous bracket on worked, obviously, but I think the spacer on the new one is wider and I can't get the bolt started. Anyone know what the size of the bolt would be to make the trip to town a little less painful by knowing at least what mm the bolt would be. Need one a little bit longer. Thanks a bunch.
Edit: I did a search, but advanced search didn't return anything and general search came back with some error page. (?)
Old 04-14-2010, 12:29 AM
Tate's Avatar
M6x1mm, not sure on the length, I think the ones I have on the AFC are 20mm long. Get some socket head cap screws, much nicer than reg cap screws.
Old 04-14-2010, 09:55 AM
infidel's Avatar
Remember there is a third bolt on the bracket down low on the back of the pump that you can't see.
No idea what size it is though.
Old 04-14-2010, 12:34 PM
Tate's Avatar
That one is also M6x1mm, but its a good bit longer, 45mm or so. I leave that one out anyway, makes taking off the shut off bracket much easier and faster.
Old 04-14-2010, 06:40 PM
infidel's Avatar
No problem leaving the lower bolt out but can cause big problems if it's left tight and the bracket is forced back to remove the AFC cover.
Bracket gets bent and the solenoid often won't line up correctly.
Result is no start or stop or restricted fuel when the solenoid binds.
Old 04-14-2010, 09:20 PM
Dojman's Avatar
That's the one I'm having problems with. The new bracket has a built in spacer for the bolt, and her old bolt is not long enough to reach the threads. The bolt worked fine on her old bracket. There must be a difference in the width of the spacer. I don't know for sure exactly what we did. I have slept since then.
Old 04-15-2010, 09:59 AM
infidel's Avatar
I've heard a couple folks complain of the wrong bracket.
They ended up getting the correct bracket from www.fostertruck.com for free.
Old 04-24-2010, 12:18 PM
Dojman's Avatar
I may have a problem there on mine. I have a no start every once in a while, new starter, new solenoid (yes the old one was bad). I am wondering what is going on there. Maybe an occasional relay problem?
I thank you guys for the help. Those were the correct bolt diameter. I had to have one a bit longer for the lower. Her truck is good.
Old 04-24-2010, 01:35 PM
Tate's Avatar
Could be a broken or corroded wire that gives intermittent contact. My dually does the same thing, I just jump out and pull the solenoid up. Does it maybe once every 25 starts, so its not the easiest to track down.
Old 06-28-2010, 11:48 PM
hotrodnewt's Avatar
The fuel shutoff solenoid relay gets its power dirrect from the batt. check the connections at the batt.
Old 06-29-2010, 09:53 AM
infidel's Avatar
Typical symptom of a wire corroded under it's insulation.
What happens is high amperage draw will "weld" the poorly conductive corroded wire back together.
Solenoid works fine for a while until corrosion wins again and cycle starts over.
It took me forever to figure out what was going on years ago with a truck that had corrosion under the ground cable.
Since then it's been one of the first places I check when there's an electrical problem.
I even had the same problem occur with a direct burial (no conduit) 440 volt 3 phase power cable. Somehow during installation the insulation was nicked allowing corrosion to get started.
Old 06-29-2010, 10:51 AM
torquefan's Avatar
The new shutoff solenoids come with a different, larger bracket because the replacement solenoid has been revised and is larger. The kit usually comes with a packet of new screws to fit the new design. Maybe you can return it and get one that's complete with the screws.
db
03-24-2009 11:14 AM
blbrowncj7
06-19-2007 02:08 PM
ajpulley
12-05-2005 10:41 PM
Paul Winey
06-02-2004 05:39 PM
RamTuffGirl
12-12-2002 11:46 PM
Quick Reply: fuel shutoff solenoid bracket bolt size
