Need Help with Tranny and Clutch
I have a 93 dodge with the getrag and i alligned the clutch right and when i put my tranny in its leaving a 1 inch to 1 1/2 inch gap in between the bell housing and the transmission it self does any one have any suggestions cause its been sittin for a week cause i cant get to go in. Thanks, Dominic
Have you tried turning over the engine a few degrees by hand, is the tranny in gear ? it sounds like the shaft is not lined up correctly, So what do you have running gear wise ...............
If its 1 to 1-1/2" back and its a dual disc, your discs aren't aligned properly. Did you use that cheap plastic alignment tool to set the discs? If so, throw it in the garbage, pull the input shaft out and use the shaft as the alignment tool. Been there a couple times, its frustrating as hell, but thats the best way of making sure the discs are in proper alignment.
Black Dog
12-03-2009 08:18 PM
Common
06-09-2008 12:16 PM
