Trany gurus, damage or bad machining?
Old May 1, 2013 | 10:51 PM
91Hoopty's Avatar
Couldnt wait for the FSM to get here and tore down my A518 today. Have no idea as to this things past and everthing seemed in good condition until I saw the rear planetary:
these knicks are above 3 of the 4 smaller gears in the exact same spot, area around the 4th gear is smooth as margarine. Just dont know enough about trans' to guess what its from, whatchya think?
Also, I COULD NOT get the OD section off until I got the front planetary snap ring off and ended up pulling the output shaft out along with the OD section, only to pull the O/P shaft out of the OD section with a tug or 2. So what in Scoobys name did I do wrong?
Old May 1, 2013 | 11:14 PM
kensmachine's Avatar
seen that befor they stake the cross pin that holds the pinon axle in nothing to worry about you want to look for pitting of the gears rocking of the gears & end play of the gears. ken
Old May 2, 2013 | 06:28 AM
j-fox's Avatar
If you plan to add much power, now is the time to replace that planetary with a steel one.
Old May 2, 2013 | 01:06 PM
cougar's Avatar
I put a 5 pinion steel in mine. Mine was cooked and about to let go. And that was with stock power. The previous owned drug a 5th wheel around with it.
Old May 2, 2013 | 04:44 PM
91Hoopty's Avatar
Thats the plan for me as well
Old May 2, 2013 | 06:49 PM
taterfarm's Avatar
sent you a private message
Old May 2, 2013 | 08:45 PM
Jim Lane's Avatar
The gears look pretty pitted, maybe overheated or dirty fluid.
Must have been getting noisy, mating gears must also be messed up.
The marks could be for identification.
Jim
Old May 2, 2013 | 09:40 PM
91Hoopty's Avatar
Jim
Definetly decided on a new set, and I bought the trans in unknown condition, fluid was black as it could be. had a snapped off cooler line fitting to boot!
J10495T
36
Dec 12, 2007 03:37 PM
rockjeep73
Feb 20, 2006 11:49 AM
guzzirider
Nov 28, 2005 07:39 PM
localnet
Jan 9, 2005 11:58 PM
Diese
Nov 13, 2004 12:05 PM
