oil cooler
Old 10-29-2014, 07:59 PM
1967david's Avatar
Exclamation oil cooler
radiator full of oil think its the oil cooler i have a 1992 12 valve
Old 10-30-2014, 01:19 AM
rrgrassi's Avatar
Sounds more like a head gasket. But...How many miles on the truck? Does the oil have water in it as well?
Automatic or manual transmission? There is a trans cooler mounted on the engine, and not in the radiator.
Old 10-30-2014, 07:03 AM
Received 2,394 Likes on 1,577 Posts
I have seen an oil cooler get holes in it and bubble oil into the coolant.
The guy replace 3 head gaskets before pulling the oil cooler, and testing it in a bucket of water with a little air pressure.
It bubbled away showing him the problem.
I had a spare on a Sunday afternoon, and he was back to work on Mon.
The head gasket is more likely, but those coolers DO go bad occasionally.
Old 10-30-2014, 08:40 PM
1967david's Avatar
pulled oil cooler sure enough it was leaking its a 1992 d350 with 89000 miles on it
Old 10-30-2014, 09:07 PM
Received 1,332 Likes on 862 Posts
Probably not running the right mix on anti-freeze. Or the water in your area has a lot of heavy minerals and stuff in it that react negatively with the metals in the block and other accessories.
I would run distilled water from the grocery store. Then you know you have nice neutral water in there.
Old 10-30-2014, 09:22 PM
funcruise's Avatar
I have a dehumidifier in the basement so would the water it produces from the damp air be the same as distilled?
Old 10-30-2014, 10:11 PM
maybe368's Avatar
Can I make a suggestion? ...Mark
Old 10-31-2014, 06:07 AM
Tank_66
01-11-2012 10:12 AM
max924
12-31-2007 10:13 PM
thumper 549
10-14-2003 11:59 AM
drafalske
04-05-2003 01:45 PM
commando
04-02-2003 06:18 PM
Quick Reply: oil cooler
