p pump gear
Old 11-25-2011, 11:08 PM
wlacroix's Avatar
Question p pump gear
I just bent the center bolt of my puller trying to get the gear loose so I could advance my timing. Yes it was a cheap puller but how hard is that gear stuck on there. Yes I have the nut loose and gear cover off to fix a oil leak. My timing is set at 13.5 and I was trying to advance it to 16 or 16.5 it is a 180pump.
Old 11-26-2011, 12:48 AM
Tate's Avatar
Load up the puller as tight as you can go, then give it a whack with a dead blow hammer from the side.
Old 11-26-2011, 01:18 AM
wlacroix's Avatar
I tried light taps with a regular hammer in hopes the vibration would brake it loose. After I get another bolt for the puller I'll try that. I was not hitting it from the side or that hard and this time use a dead blow. Thanks !!!
4969joes
03-27-2010 08:58 AM
JohnInNH
15
09-03-2006 08:22 AM
mhuppertz
08-19-2006 09:17 AM
trout74
08-29-2005 06:25 PM
Hummin Cummins
12-25-2002 12:29 AM
Quick Reply: p pump gear
