HELP, pulling injector pump, pulled pump gear so hard bolt broke off in gear
Old Mar 25, 2010 | 10:00 PM
4969joes's Avatar
Angry HELP, pulling injector pump, pulled pump gear so hard bolt broke off in gear
i have the pump ready to pull, all i needed to do was pull the gear using a very nice heavy duty mac gear puller, and after ALOT of tourque and gear not popping off, one of the bolts from the puller broke off in the gear, the nut was on there pretty good but no harder than 150 lbs of tourque so why in the world wont this gear pop off. Now i have to pull the timing gear cover to extract the bolt out of the gear but i still need to get the gear off the pump. ANY tricks on doing this will be a great help as i am getting very frustrated with my 12 valve that i dont even get to drive because all i ever do is work on it!!!!
Old Mar 26, 2010 | 12:30 AM
Tate's Avatar
Are your turning the jack bolt in the puller, or the bolts that screw into the gear?
When I have a gear that gets hard to come off, I put a good amount of pressure on the puller and then smack it with a dead blow hammer. If that doesn't do it, I put more pressure on it and do it again.
Old Mar 26, 2010 | 05:35 AM
sewman's Avatar
Take a small screwdriver & try to spin the broken piece out,it doesn't have any pressure on it .
Old Mar 26, 2010 | 08:48 AM
4969joes's Avatar
thats a great idea with the screw driver, i was putting all the pressure on the jack bolt then tapping it with my ball peen, this puller is putting alot of pressure on the gear, i dont know how anyone could be getting these off with steering wheel pullers?? any other suggestions??
Old Mar 26, 2010 | 09:31 AM
infidel's Avatar
Use grade 5 bolts in the puller.
Grade 5 will bend before breaking, grade 8 breaks.
Old Mar 26, 2010 | 11:21 AM
4969joes's Avatar
thanks infidel, i will give that a try today
Old Mar 26, 2010 | 12:17 PM
Fishguy 50's Avatar
Tates advice was good, load up the puller, then strike the puller dive bolt. This dose work.
Old Mar 26, 2010 | 12:46 PM
BigIron70's Avatar
Cummins Guru
I always tighten the bolts to remove gear, just use a flat washer and screw bolts into gear three turns then snug up center bolt on puller. Tighten equal on each bolt a little at a time until gear pops loose. I wear work gloves because when gear pops loose it will definely hurt your hand on the wrench.
Old Mar 26, 2010 | 04:24 PM
Tate's Avatar
If he is using the intake horn bolts, they are 9.8, which is just a bit stronger than a grade 5.
Old Mar 27, 2010 | 08:58 AM
4969joes's Avatar
got it off guys, thanks for the help
txarrowhunter
Aug 22, 2010 04:45 PM
4969joes
Mar 28, 2010 05:26 PM
Oldschooldodge
Jan 2, 2008 03:42 PM
blueboy16
Jan 31, 2007 11:44 PM
Stevenc
Sep 27, 2004 06:32 PM
