more smoke now, why?
I have a 91 IC with the fuel screw turned in two turns and a HX35 turbo.
It's been running great, but lately I notice alot more black smoke when under boost than I used to have before, just started doing it.
The truck has 300,000KM, I'm wondering is time for a set of 190 replacement injectors?
Turning in the fuel screw will cause more black smoke. If it didn't do it when you first turned it in you may have a boost leak somewhere which is causing you to smoke now when you weren't before.
I pressure tested my intercooler today, it gave me soap bubbles all over the place. Looks like I'll have to get a new one.
Does anyone know anything about the replacement units from Piers?
Are they OEM replacements or are they an improved model?
Hook the intercooler up by itself and do a pressure decay test before you condemn it. Air it up to 25 psi and remove the air supply. The pressure should drop no more than 7 psi in 30 seconds.
Mine has been known to stick the pin at full fuel. It started a fight with an edged 6 oh no this weekend for that very reason, he stopped chasing me (falling back) after 2 miles with the speedo buried.
Mark Hodowanec
44
Mar 28, 2008 11:47 AM
BlackSheep5
Nov 27, 2006 07:52 PM
Ramstang
35
Aug 21, 2006 07:43 PM
PsRumors
Mar 11, 2006 05:52 AM
