HELP with TST Comp
Old Jul 9, 2007 | 07:36 PM
SFA's Avatar
SFA
HELP with TST Comp
I installed a TST comp and a FASS on my 2000 3/4 ton 5speed on Thursday. So far it has been GREAT. Today I was comming home on level 4 TST going about 55 to 60 and stomped on it to get up around someone and my truck started bucking like it the power was kinda cutting on and off. I can get it to do this every once in a while but does not do it all the time. I dont know if this is what people call dead pedal or if this is different. what could be wrong?
Old Jul 9, 2007 | 07:44 PM
bnold's Avatar
Do you have a fuel pressure gauge?? If not get one.. may be running the injection pump out of fuel... If pressure is good may be pushing a weak IP too hard...
Old Jul 9, 2007 | 07:51 PM
SFA's Avatar
SFA
yes my fp with the fass never drops below 13psi, boost gets up to about 32.
Old Jul 9, 2007 | 07:58 PM
bnold's Avatar
Ahh skipped the FASS part... Fuel pressure is good then... TST fuels very hard... I'll experience a shudder when backing off the throttle on 7 or above.. Most think it is the pump cavitating
Old Jul 9, 2007 | 08:09 PM
SFA's Avatar
SFA
Yea, I get the shudder on let off when I am in upper levels also, but this is when I push the throttle. it is like it just wants to die, come back and die real fast like. almost like you turn the key off for a half second then turn it back on, off, on, off .......
Old Jul 10, 2007 | 06:55 AM
Mike D's Avatar
Check your fuse.
Old Jul 10, 2007 | 12:05 PM
Stamey's Avatar
Originally Posted by Mike D
Check your fuse.
Check what fuse? My PM3 Comp always does this if you don't run it out to redline on levels above 4, and I get a little shudder on 4 too. Never actually established what causes this, but it hasn't hurt anything that I'm aware of, yet.
Chris
Old Jul 10, 2007 | 12:12 PM
Mike D's Avatar
I was responding to this, Chris. If the fuse is loose it could act this way.
I have the Comp too by the way, mine runs fine on the upper levels, I only get the shudder when letting out of the fuel, levels 4 and above.
Old Jul 10, 2007 | 12:19 PM
Mike D's Avatar
Sorry, I just realized you have a 5 speed. The Comp could act this way on a handshacker as TigerRag's is pretty ragged on the up levels. I would still check the fuse to make sure it in there tight.
Old Jul 10, 2007 | 01:25 PM
95ram's Avatar
I would also check the connection at the IP. If you dont have a solid connection it will shudder. Where is your ground?
Old Jul 10, 2007 | 01:54 PM
mcoleman's Avatar
Bingo, Check the connections, and watch and see if the lights on the box are blinking when it is missing.
Old Jul 10, 2007 | 03:25 PM
Stamey's Avatar
10-4, Mike.
Chris
Old Jul 11, 2007 | 08:45 AM
chadder1313's Avatar
The same here!
Old Jul 11, 2007 | 09:06 PM
Chevyboy51's Avatar
solder your pump wire that little push on conector is a pos the first TsT I put on for a customer had that problem since then I solder all of them I install
dodgediesel
Dec 14, 2006 09:54 AM
dodgediesel
24
Oct 25, 2006 04:40 PM
getblown5.9
13
Oct 4, 2006 04:59 PM
rockjeep73
Mar 25, 2005 03:34 AM
hellotbone
Jul 12, 2003 12:58 AM
