Couldn't Stand the Pressure
Old 12-12-2006, 08:09 AM
59FORD's Avatar
What happens when you drop a valve at 3200 ??
Things go bumpty bump clackety clack bangety bang...puff puff
THE LINKS BELOW ARE NOT FOR THE FAINT HEARTED!!
Click at your own risk, you have been warned.
Head
All most turned the head into a Hemi
Piston
YEP, that's the valve head in the center
Busted the block, killed the head, ruined a nice sunny day.
I pulled this engine about a year ago and waited till yesterday to
pull the head. Kinda, in the back of my mind hopeing it had healed
by some miracle.
can ya say....OUCH!
Now it's time to build my P pumped FORD Cummins (yeah it does say FORD) on the ID tag.
Old 12-12-2006, 08:47 AM
Begle1's Avatar
Man, you need to put some warnings on those pictures. Those things aren't for the weak of heart.
What were the mods at the time of that?
Old 12-12-2006, 09:18 AM
59FORD's Avatar
MODS????
This was a fresh rebuild with 15k on it. 1/2 on the fuel, 3200 spring, HX35/16
THAT WAS IT!
Just a bad valve I guess. (sniff sniff)
Old 12-12-2006, 09:25 AM
timb's Avatar
Dude! That aint right posting dirty pictures like that for us to see. That is some major carnage that happened there. I'd imagine that it sounded like a ford when it turned loose.
Old 12-12-2006, 09:40 AM
Begle1's Avatar
Originally Posted by 59FORD
MODS????
THAT WAS IT!
Did you rebuild it yourself?
If somebody else did it, I'd hope it was under warranty. Must have been a bad valve.
(Yes, I enjoy stating the obvious for the third time, thank you... )
Old 12-12-2006, 09:56 AM
59FORD's Avatar
Yep, my build, with all new Cummins parts. The head only had 78k since
it was new. Just did a quick lap on the valves and checked for leaks.
Everything look fine, nice clean engine to start with, NO major wear..nada
nothing, just a freshen up job.
Old 12-12-2006, 10:01 AM
59FORD's Avatar
Timb
Actually it sounded like an old worn out dodge slant 6.......LOL
Old 12-12-2006, 12:59 PM
Ilikebikes's Avatar
Ouch!! That is rough. But like you said, now you can get a P pump!!!
Old 12-12-2006, 07:08 PM
I've seen one like that. Same kind of failure, stock motor (swapped into a Ford even, I kid you not) swallowed a valve. Maybe they just don't like being in Fords?
Old 12-12-2006, 07:11 PM
59FORD's Avatar
I'll let that one pass...for now
It was the ole number 1 syndrome I guess
BTW, what's up with the pics in post deal. I couldn't get
any thing to work.
Old 12-12-2006, 07:20 PM
Just click on the little button in the reply box, and paste the url of the pic in the dialog box that pops up.
The pic will show up like so:
Old 12-13-2006, 01:54 AM
Ilikebikes's Avatar
I'm going to look at some parts tomorrow and one of them happens to be a '98 12v short block with 116k on the ticker. Dropped a valve like yours in #1. Where is the crack, if visible? What are the chances of cracking a the block when a valve drops? The guy says the cyl wall still looks fine and useable. If it looked ok, I was gonna hone it and put a new piston in it and run it. I'm assuming that if the cyl wall is still useable, then it may have dropped at a low RPM and shut off immediately. Any input is appreciated!
Life is Life
16
04-17-2005 06:15 PM
Bigredmachine
16
03-01-2005 11:57 AM
98 2500
04-19-2004 09:31 PM
nascar mark
05-01-2003 12:20 AM
Quick Reply: Couldn't Stand the Pressure
