Couldn't Stand the Pressure
What happens when you drop a valve at 3200 ??
Things go bumpty bump clackety clack bangety bang...puff puff [laugh] THE LINKS BELOW ARE NOT FOR THE FAINT HEARTED!! Click at your own risk, you have been warned. Head All most turned the head into a Hemi Piston YEP, that's the valve head in the center Busted the block, killed the head, ruined a nice sunny day. I pulled this engine about a year ago and waited till yesterday to pull the head. Kinda, in the back of my mind hopeing it had healed by some miracle. can ya say....OUCH! Now it's time to build my P pumped FORD Cummins (yeah it does say FORD) on the ID tag. |
Man, you need to put some warnings on those pictures. Those things aren't for the weak of heart. [tapdshut]
What were the mods at the time of that? :o |
MODS????
This was a fresh rebuild with 15k on it. 1/2 on the fuel, 3200 spring, HX35/16 THAT WAS IT! Just a bad valve I guess. (sniff sniff) |
Dude! That aint right posting dirty pictures like that for us to see.[yuk] That is some major carnage that happened there. I'd imagine that it sounded like a ford when it turned loose.:o
Originally Posted by 59FORD
(Post 1248448)
MODS????
This was a fresh rebuild with 15k on it. 1/2 on the fuel, 3200 spring, HX35/16 THAT WAS IT! Just a bad valve I guess. (sniff sniff) If somebody else did it, I'd hope it was under warranty. Must have been a bad valve. (Yes, I enjoy stating the obvious for the third time, thank you... [duhhh] ) |
Originally Posted by Begle1
(Post 1248481)
Did you rebuild it yourself?
If somebody else did it, I'd hope it was under warranty. Must have been a bad valve. (Yes, I enjoy stating the obvious for the third time, thank you... [duhhh] ) it was new. Just did a quick lap on the valves and checked for leaks. Everything look fine, nice clean engine to start with, NO major wear..nada nothing, just a freshen up job. |
Timb
Actually it sounded like an old worn out dodge slant 6.......LOL |
Ouch!! That is rough. But like you said, now you can get a P pump!!! :D
I've seen one like that. Same kind of failure, stock motor (swapped into a Ford even, I kid you not) swallowed a valve. Maybe they just don't like being in Fords? :p
I'll let that one pass...for now :(
It was the ole number 1 syndrome I guess BTW, what's up with the pics in post deal. I couldn't get any thing to work. |
Just click on the little https://www.dieseltruckresource.com/...nsertimage.gif button in the reply box, and paste the url of the pic in the dialog box that pops up.
The pic will show up like so: http://www.citlink.net/~rawdeal/head.jpg |
I'm going to look at some parts tomorrow and one of them happens to be a '98 12v short block with 116k on the ticker. Dropped a valve like yours in #1. Where is the crack, if visible? What are the chances of cracking a the block when a valve drops? The guy says the cyl wall still looks fine and useable. If it looked ok, I was gonna hone it and put a new piston in it and run it. I'm assuming that if the cyl wall is still useable, then it may have dropped at a low RPM and shut off immediately. Any input is appreciated!
