2002 disc brake question
Old 08-19-2008, 08:26 PM
fozzy's Avatar
Can anyone tell me if the 2002 rear disc brakes use short flex hoses from the steel line to the calipers? It should but I'm unable to find the hoses in the aftermarket so far. Got an OE part number by chance.
Switching newer diff into my '92 and the donar axle came without brake lines.
Old 08-19-2008, 08:33 PM
screamin01's Avatar
I would call EGR brakes. They do a lot of custom brake lines for dodges.
He is there website http://www.egrbrakes.com/index-main.htm
Old 08-19-2008, 08:48 PM
Stormin_Norman's Avatar
On my 2002 3500, the last 4" or so is rubber flex line. I'd find a donor or make my own, Napa should have a variety of flexible hose.
Old 08-19-2008, 09:42 PM
duner's Avatar
most speed shops carry stainless braided brake lines in several lengths.
Old 08-20-2008, 12:49 AM
fozzy's Avatar
I just might end up having some made. I knew they would be short flex hoses and was surprised that the local parts store only had a listing for the center flex hose.
Old 04-15-2009, 01:57 AM
fabricator's Avatar
I am also having this problem.
anyone khow where I can get the flexable hoses
from the calipers to the hard lines on the rear.
Old 04-15-2009, 09:52 PM
SWC
SWC's Avatar
You need to replace the whole thing hardline and flex.
I agree with screamin01, check with EGR Brakes.
Just for giggles call your local 5 star dealer and ask for a price on those lines.
(Be sitting for the response and quickly slap duct tape over your mouth so you don't insult the poor parts man!!!)
Stan
Old 04-16-2009, 12:27 AM
fabricator's Avatar
i understand that i need to replace all the lines
didn't know if anyone has been thru it
will call EGR brakes in the morn
Old 04-17-2009, 12:28 AM
fozzy's Avatar
Being impatient I ended up getting a set from a wrecked truck. Not the best solution but it worked for now. I think flex hoses from just about any application would work as long as the banjo bolt goes through the block.
Old 04-17-2009, 06:17 AM
North_of_55's Avatar
I'm not sure what it would be like down in the USA but I was quoted over $1,000 CAD just to purchase those 2 hoses from the dodge dealer in my town!
Does this translate to: "We don't have any of them so lets set the price so high that nobody buys them?"?
Turns out my hoses were okay... just had to replace both calipers!
Old 04-18-2009, 04:03 AM
fabricator's Avatar
well, EGR wants 140 dollars for their version
My version is gonna be less than 40 bucks
will post part #'s after I make sure everything works
under pressure...Installing rearend this weekend hopefully
Robert Rausch
11-17-2011 10:21 AM
pullin hard
03-05-2009 08:06 PM
n2moto
16
01-22-2009 10:25 PM
ShawnQ
01-12-2006 08:09 PM
kwhite4
05-09-2005 03:22 PM
Quick Reply: 2002 disc brake question
