2002 disc brake question
Old Aug 19, 2008 | 08:26 PM
fozzy's Avatar
Can anyone tell me if the 2002 rear disc brakes use short flex hoses from the steel line to the calipers? It should but I'm unable to find the hoses in the aftermarket so far. Got an OE part number by chance.
Switching newer diff into my '92 and the donar axle came without brake lines.
Thanks
Old Aug 19, 2008 | 08:33 PM
screamin01's Avatar
I would call EGR brakes. They do a lot of custom brake lines for dodges.
He is there website http://www.egrbrakes.com/index-main.htm
Old Aug 19, 2008 | 08:48 PM
Stormin_Norman's Avatar
On my 2002 3500, the last 4" or so is rubber flex line. I'd find a donor or make my own, Napa should have a variety of flexible hose.
Old Aug 19, 2008 | 09:42 PM
duner's Avatar
most speed shops carry stainless braided brake lines in several lengths.
Old Aug 20, 2008 | 12:49 AM
fozzy's Avatar
I just might end up having some made. I knew they would be short flex hoses and was surprised that the local parts store only had a listing for the center flex hose.
Old Apr 15, 2009 | 01:57 AM
fabricator's Avatar
I am also having this problem.
anyone khow where I can get the flexable hoses
from the calipers to the hard lines on the rear.
Old Apr 15, 2009 | 09:52 PM
SWC's Avatar
SWC
You need to replace the whole thing hardline and flex.
I agree with screamin01, check with EGR Brakes.
Just for giggles call your local 5 star dealer and ask for a price on those lines.
(Be sitting for the response and quickly slap duct tape over your mouth so you don't insult the poor parts man!!!)
Stan
Old Apr 16, 2009 | 12:27 AM
fabricator's Avatar
i understand that i need to replace all the lines
didn't know if anyone has been thru it
will call EGR brakes in the morn
Old Apr 17, 2009 | 12:28 AM
fozzy's Avatar
Being impatient I ended up getting a set from a wrecked truck. Not the best solution but it worked for now. I think flex hoses from just about any application would work as long as the banjo bolt goes through the block.
Old Apr 17, 2009 | 06:17 AM
North_of_55's Avatar
I'm not sure what it would be like down in the USA but I was quoted over $1,000 CAD just to purchase those 2 hoses from the dodge dealer in my town!
Does this translate to: "We don't have any of them so lets set the price so high that nobody buys them?"?
Turns out my hoses were okay... just had to replace both calipers!
Old Apr 18, 2009 | 04:03 AM
fabricator's Avatar
well, EGR wants 140 dollars for their version
My version is gonna be less than 40 bucks
will post part #'s after I make sure everything works
under pressure...Installing rearend this weekend hopefully
Robert Rausch
Nov 17, 2011 10:21 AM
pullin hard
Mar 5, 2009 08:06 PM
n2moto
16
Jan 22, 2009 10:25 PM
ShawnQ
Jan 12, 2006 08:09 PM
kwhite4
May 9, 2005 03:22 PM
