Code Talker Neaded
Old Apr 17, 2009 | 02:02 PM
wildcargo's Avatar
Code Talker Neaded
Got a P0500 & P1693 .
Drove down to WV yesterday from South Jersey every thing seamed fine. Left WV this morning and 1/2 mile down the road a cupple of hiccups from the truck went about 25 miles and when geting on the highway it hicuped again. I stoped and filled the tank thinking it might be easier on the lift pump, no more hicupes all the way home , truck seams to be running all right but got them codes when I got home.
So what do you think
Old Apr 17, 2009 | 05:14 PM
Chaser10's Avatar
Not familiar with that one, but here's what I found:
P0500-NO VEHICLE SPEED SENSOR SIGNAL
Old Apr 17, 2009 | 05:20 PM
Chaser10's Avatar
The 1693 just means your PCM detected a DTC.
By "hiccupped", do you mean a little miss to the engine, or something much greater? I'd change fuel filter first, then make sure you lift pump is providing required pressure. Couple times I've had that "little miss" and new filter was the answer.
Old Apr 18, 2009 | 06:08 AM
wildcargo's Avatar
Thanks I'll try a new filter and see if I can rig a presure gauge
coope3
Feb 21, 2009 04:49 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
bkay
Mar 25, 2003 10:41 AM
