Wiring question
Old Sep 8, 2005 | 09:04 PM
ramking2004's Avatar
Wiring question
I have a Cruiser 5 th wheel and when the dealer set it up I told him I wanted to be able to power the trailer and be able to charge the battery as I drove down the road.It worked for a while and now it doesn't.I know it might sound stupid to most but can I assume that I have blown a fuse in the truck?I still have running lights ect but the power jacks won't work if I plug into the truck.Can someone tell
me what to do or check.
Thx Rick
Old Sep 8, 2005 | 10:16 PM
fschiola's Avatar
How about checking the fuses in the power distribution center under the hood on the left side fender. See if you have power to the plug on the rear of the truck. On mine it's the center pin.
Old Sep 9, 2005 | 02:44 PM
the real FYRMAN's Avatar
You may have to do some digging to find it, but there should be a fuse somewhere on the trailer side too.
Old Sep 9, 2005 | 10:49 PM
SuperGewl's Avatar
This is one of those must get fixed things. If what you are saying is tru then you also don't have trailer brakes for long or possibly at all. You most definatley don't have Emergency trailer brakes without power to the trailer. My fuse on the trailer is in the 5VR hitch where the cable goes. If your truck checks out OK then you may have blown a fuse up in there.
Another check is to see if someone didn't trip the breaker or open the battery circuit on the 5vr last time you put it in storage. That switch that you either pull/push or trip will open circuit the batteries but still allow yo to have running lamps powered from the truck.
Old Sep 9, 2005 | 11:33 PM
torquefan's Avatar
If the trailer connector is a 7 pin, the power terminal is one of the top ones, on one side of the index slot. The center pin is "aux" (usually reverse lights.)
The pin should have power with the key on. Some are hot all the time.
Old Sep 10, 2005 | 03:50 PM
2500Ram's Avatar
I just had a dead battery on the trailer, replaced and wasn't paying attention and wired the battery up backwards, positive on negitave, big spark corrected the battery. No biggie, went camping brakes were fine, running lights ect. Camped for a few days and checked the battery indicator in the camper and they were dead. Checked the batteries, both fine, checked the main positive 30A fuse in the camper control box and it was blown. Replaced the fuse and the batteries were charging again.
Old Sep 10, 2005 | 08:13 PM
fschiola's Avatar
I'm glad you got it sorted out.
Old Sep 10, 2005 | 09:46 PM
2500Ram's Avatar
My problem yes but ramking2004 is still having problems unless you know something we don't.
Old Sep 10, 2005 | 09:58 PM
fschiola's Avatar
Really need to have him tell us what he found out on the tests he ran.
Old Sep 11, 2005 | 06:49 PM
I had a bad battery for one thing.I replaced it and disconnect it when not in use.We went camping this weekend and I did not have a problem with any electrical issues.Brakes worked fine.I did replace the fuseable link (30A) with a 30A circuit breaker.If the trailer is plugged into the truck And battery is disconnected I still do not have power to the jacks.What is the fuse number in the distribution box? I haven't checked that yet.I will keep ya'll posted.
Thx Rick
wyododge
Jan 13, 2009 02:25 AM
Evildiesel
Jul 2, 2006 06:39 PM
charcoal600
Apr 30, 2005 02:34 PM
alan1
Oct 17, 2003 06:42 PM
Madoco
Oct 13, 2003 08:50 PM
