weight
If your truck is a 2500.......the gvwr is 9000lbs. That is the weight, including pin weight, of the cargo capacity of your truck (if you are trying to stay within Dodge's ratings).
The GCVWR (weight of Truck and Trailer and cargo of both) is 21,000lbs with 3.73 gears and 23,000 with 4.10s.......according to Dodge.
We all know the trucks can haul much more than that. As long as you are within the tires ratings you will probably be fine.
Just stay with ratings on your tires, and your axle ratings, The axle ratings can be found on the door sticker. My 96 2500 , I have crossed many scales and never had a problem, I have weighed in as much as 6200 pounds on the back axle of the truck and not a problem,total weight of the truck was 10,400 pounds, and with trailer it was just pounds under 20,000. just remember you break that 26,000 pound mark total weight and a CDL is required. My 2500 is legally licenced for 20,000 pounds total weight.
he is already in the need for a class a liscense due to the fact that his trailer is gvw at 22k add that to the truck and he is over the 26k. the commercial deal is another story that can be researched here before gettin a bunch of replies about it
Well, again, it'll depend on his home states regs. He may have a provision, like I do in my state, that I can be exempt if I'm hauling personal items. I can scale out at 32K GCW and as long as I'm under axle weight ratings I don't need any level of a CDL.
weight on truck
1ST no need to worry about cdl, I have a class A. I know A lot about BIG TRUCKS, 80K plus. These pick up trucks are small for me and the info seems to be less openly out there for them.
I read through my manual and looked on my door and some of the info seemed abiguous. According to the manual it calculated out pretty light.
I registered my 2500 for 9500 lbs. and my trailer for 22500 lbs. So the total registered gross wt is 32,000.
The door say 5200 on front and 6000 on rear. GVWR is 9000 too. SO ????
How much wt can my drive axle on my truck weigh and be legal and how much can it take?
Can I actually register my truck for 11200 gross and put 5200/6000 on the axles. Have a total wt of 33700?
What do you think!
What do you think!
read what i said there are states that offer noncdl class a's texas is one of them . didnt say commercial he needed a cdl. 33k seems like a lot for a 2500 to me.
What do you think!
What do you think!
Purplezr2
Jul 25, 2011 04:31 PM
COHUTTA MNT KID
Oct 12, 2002 08:17 PM
26000 will i need a cdl
