Stock or Not
Old Oct 16, 2002 | 11:24 PM
TommysBlue's Avatar
Stock or Not
I'm in the process of buying a 30/ft 5th wheel, thats weighs about 9800 lbs empty and maybe 11500, fully loaded. I currently pull a 28/ft, 8500 lbs Travel Trailer with no problems. So my question is can I pull that much weight with my &quot;stock&quot; Auto Transmission. I really don't want to spend any more money on the truck. My wife would kill me if I told her.. Honey, after spending 30,000.00 plus for my truck &amp; a cool $ 35,000.00 on the new 5th wheel, I need to spend more money (that I don't have) to trick out the transmission :'(.. Yeah that would happen... What do ya think ???<br><br>Tommy
Old Oct 17, 2002 | 06:42 AM
TPilaske's Avatar
Re:Stock or Not
Personally, I would slap at least an EZ on it. Check for a used one. You should be able to get that at a decent price! ;D I'm sure some of the veteran towers can help you out more.<br><br>Tony
Old Oct 17, 2002 | 06:48 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Stock or Not
I would opt for a set of gauges at the very least.<br>Pyro (EGT), Fuel pressure and Auto Tranny Temp, if you're planning on towing heavy. That way you can keep an eye on what's happening before the &quot;Idiot lights&quot; tell you there's a problem.
Old Oct 17, 2002 | 07:03 AM
TPilaske's Avatar
Re:Stock or Not
Ahhhh yes, the gauges. Always forget that the A-Pillar is not stock! ;D So gauges, an EZ, tranny mods.... heh... j/k... ;D
Old Oct 17, 2002 | 07:55 AM
Bill1374's Avatar
Re:Stock or Not
Tommy,<br> My 95 tranny is still stock and does OK at about 18k gross. I don't let it hunt and I don't let it lug at low rpms and it does fine. Will it last? Probably not at these weights but for now its Ok and has been for 4 years.<br><br>Bill
Old Oct 18, 2002 | 09:48 PM
Snoking's Avatar
Re:Stock or Not
4:10's or 3.54's, 4:10's are much better for towing with the 24V Auto's. Shift down below 1800RPM's, take it out of OD manually on hills. Around town lock out OD. Spend some time reading everything at this site:
http://www.dieseltrans.com/phpBB/index.php
SNOKING
Old Oct 19, 2002 | 10:39 AM
FiverBob's Avatar
Re:Stock or Not
And change tranny fluid often. :P
CentralTXDodge
Mar 3, 2009 09:15 PM
D45
Aug 11, 2008 12:26 AM
jgiachino
May 12, 2008 02:06 AM
cumminsdriver635
Aug 8, 2005 05:46 PM
sammy340
Apr 5, 2005 03:55 PM
