LT235/85R16 Tire Pressure?
Re: LT235/85R16 Tire Pressure?
Originally posted by edwinsmith
I have an 89 D-35 dually with LT235/85R16 tires x 6. The door plate is faded but seems to say 50 PSI for the front tires. Anyone know for sure?Thanks Edwin
I'm running 68 right now.
When I tow again I'll air up to 75 front/rear.
With 1500# on my FW pin I have front and rear axles loaded at 4500# each, 2250# per tire on my SRW truck.
Re: airing down and "watching for heat build up while towing".... I think the likely first sign of this would be a blow-out? unless you're shooting the tires with an IR thermometer every 20 minutes?
Maybe I'm just used to it, but I don't think the ride is bad at all.
Running that weight you need to run the max 80 pressure, cold, for safety. Bet if you check you are lowering the capacity so that the tires are overloaded.
Edwin, your truck probably came with 215's. Seems mine were rated for 60. Your 235's should be up to 80 PSI as stated. I have my Coopers at 70. Don't pull anything. Most loads are local.
mt72916
06-14-2010 08:37 AM
doomgaze
03-20-2006 05:50 PM
