Installing 7 Pin In Bed, need help.
So I bought the valley adapter kit to install my 7 pin in bed to hook to a gooseneck, issue is I can find the factory plug, does anyone know were it is, my 7pin at the back of the truck on the hitch is wired straight in, no plug there, did someone cut the plug of or am I missing something. Thanks
Here is what I have done for years and it works great. Make an extension male plug at one end and a female plug for the bed end. Make it long enough so that it goes over the the top of the rear bumper and then run the cable under the bed and over the frame to where you want to locate the female. Drill your holes, feed the wire through install your female end onto the wires and then mount that to the bed. That way you are not cutting and splicing wires that will just lead to future corrosion.
Joe
By the way, check out www.gooseneckshades.com they may have something you can use! Its pretty darn cool, no pun intended!
Joe
Do it the easy way. Tie in at the back. I located my new plug in the side of the bed about 1' forward from the tail gate and about 4" up from the floor - - lots of space to to get it from under the truck. Locate the matching wires coming from the bumper 7 pin and solder your pigtails from the new plug to them, then seal the connections weather tight. Use some flex wire guard to finish off your install. Took about one hour total. Now both plugs work.
Bob
Bob
I'm guessing someone cut the plug. My 2000 had the plug on the back of the trailer plug that the Valley kit plugged in to.
All good suggestions here. Cut the plug off the Valley and solder it into the harness, Wire a 7way onto the end of the Valley harness and just plug it in, or ditch the in-bed idea and extend the cable on the trailer.
Personally, I'd just solder the wires in behind the bumper. Don't have to mess with a plug that way and extending the trailer cable only works if all you pull is your own trailers.
On my 03 I knew I was going to trade up, so I bought a trailer extension cord (male on one end, female on the other). I didn't want it draped over the tail gate and chaffing up the paint, so I took one end off the extension and threaded it through the hole on the side of the stake pocket, down through to the rear bumper, and put the end back on and plugged it in. Then I just zip tied the female part to the tie down ancor in the bed of the truck.
For the 06, I installed a socket inside the bed, using the one that hooks to the factory connector at the back of the bumper plug.
If yours doesn't have the connecor at the back of the socket on the bumper, I'd presume the truck wasn't ordered with the tow package, and aftermarket stuff was put on, in which case splice with solder and shrink tubing might be required (or just use an extension).
Cowboy_Customs
Oct 18, 2011 01:46 AM
