Fuel Tanks
Old Aug 15, 2005 | 08:51 PM
09621's Avatar
Fuel Tanks
I purchased a 2005 2500 CTD 2wd in may. What's my options on auxiliary fuel tanks. 30 to 50 gallons.
Old Aug 15, 2005 | 09:18 PM
Buzz's Avatar
Try this: Transferflow
Old Aug 16, 2005 | 12:25 PM
Steve034x4's Avatar
From: North of the Frost Line....near Priddis Alberta
If anyone has insight into an aux tank that fits UNDER the bed, please shout. I know of some (e.g. SuperTank), but apparently it hangs 3 in under the frame and that's no good for a 4x4.
Old Aug 17, 2005 | 12:06 PM
Lightman's Avatar
09621 check out rds aluminum. They are sold thru northerntool mostly, but you can buy direct as well. I have a 51 gal aux tank/toolbox combo that with installation cost me about $520. Transferflow has some nice options but way too many electronic gimmicks/gizmos for my taste, and they are way expensive. I prefer a simple ball valve and to gravity feed into the main tank. For all of you out there that are uninformed, gravity feeding to your main tank is LEGAL. Gravity feeding into your fuel system/engine is not.
Old Aug 18, 2005 | 05:32 AM
Gear Poet's Avatar
23 gallon circle track tank from Summit, cheap electric fuel pump from Advance Auto, wiring, switch, fuse, ball valve, transmission hose, inline filter, feeds directly into top of the main tank. Total cost, $241, total mileage w/o problems, 35,000, total time used without problems, 25 months. Total times cops and/or inspectors have looked at me sideways, zero.
Old Aug 18, 2005 | 05:48 PM
Kauaitransport's Avatar
I have the 91 gallon fuel/toolbox combo from RDS with the switch in the cab to change tanks and it works good. Search RDS Aluminum on DTR there is some good threads on the subject. Cost Tank $429.00 Install Kit $279.00
Old Aug 20, 2005 | 09:36 AM
09621's Avatar
Thanks for everyone's suggestions. I think I'm going with RDS Aluminum. Again thanks.
Old Aug 22, 2005 | 03:41 PM
VACHZHD's Avatar
Kauaitransport: Can you share where you found the RDS 91 gallon tank combo for that price? The best I have been able to find is 599.99
Old Aug 23, 2005 | 07:18 PM
Mntngoat's Avatar
Aero Tanks makes a large replacement tank if you happen to have a longbed.
Michael
ocsurf16
Sep 25, 2006 10:36 AM
moss2904
13
Mar 24, 2003 02:36 PM
Buzz
Jan 31, 2003 07:16 PM
DJ
Oct 20, 2002 03:27 PM
