Factory trailer brake connection
Old Oct 26, 2004 | 05:06 PM
apache's Avatar
I have a 95 2500 4x4. I was told the 4 wire plug under the dash is for a trailer brake connection but i will need to go to the dealer for the male end that goes into it then actually will splice into the new brake setup. Is the dealer the only place? Im pretty sure the hitch and 7 pin flat type connector are factory goodies.
Old Oct 26, 2004 | 05:42 PM
RATTLINRAM's Avatar
I'm sure that you can find that pig-tail at any place that sells the brake controllers. Most auto supply stores (AutoZone,, AdvanceAuto,,,,, NAPA,,,, PepBoys,, etc) should have them. I have even seen them at the Agri-Supply here in VA. Most hitch shops should carry them also.
Old Oct 26, 2004 | 06:59 PM
SuperGewl's Avatar
Almost every TT dealer will have the pigtails aready made up to connect directly into the Brake controller
Old Oct 26, 2004 | 09:22 PM
apache's Avatar
Good deal , Ill pick one up. Also wondered on controllers. Our stock trailer has brakes on all 4 wheels, are most rated for 2 or 4 wheel service? I was runnung a drawtite and never could get it right it seemed. Either to much or not enough. hope to find something better.
Old Oct 26, 2004 | 09:56 PM
FiverBob's Avatar
Either Jordan or Prodigy will handle up to six wheels. Sure do recommend the Jordan - - much smoother than the Prodigy.
Old Oct 27, 2004 | 05:18 AM
Casey Balvert's Avatar
BrakeSmart while pricey provides stops as smooth as a baby's bottom. Your cattle will love you for it.
Casey
sootnsmoke
Sep 5, 2012 12:23 AM
ColoRoadie
Jul 13, 2011 09:17 AM
mattym
Apr 6, 2009 10:03 AM
rico334
Sep 27, 2006 12:43 PM
scuzman00
Mar 10, 2005 07:37 PM
