Factory brake controller connection
Old Jul 16, 2012 | 11:54 PM
sootnsmoke's Avatar
I am getting ready to install a brake controller in my 96 2500. It never had one installed but does have the factory tow package. The owners manual says there is a connection for an aftermarket controller to be plugged into under the dash. Can't see it anywhere under there. Can someone tell me what it looks like our post a picture of it?
Old Jul 17, 2012 | 05:51 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Look under the dash near where the harness passes through the firewall.
It should be a multi-plug that looks kinda like this.
Old Jul 17, 2012 | 09:52 AM
infidel's Avatar
I haven't seen a connector on a 12 valve but rather a bundle of wires in the upper parking brake area labeled trailer.
Beware when hooking the controller up.
Most controllers have the same colored wires as you'll find under the dash but only a couple of the same colors need to be connected to the same color.
Makes it confusing and a wiring diagram necessary.
Old Jul 17, 2012 | 12:31 PM
joem's Avatar
I did alot of research on this 6 months ago when I added my controler, in 1994 and 1995 dodge only had one blue wire. In 1996 they added a inline 4 plug labled trailer controler. its just above the pict shovelhead posted.
Old Jul 18, 2012 | 03:06 PM
sootnsmoke's Avatar
Great, I will look for that connector. Is that inline 4 plug capable of just being plugged into a standard connection on new brake controllers being sold today? Is there any additional wiring that needs to be done to make the required connections to it or is it just plug and go with that plug added in 1996?
Old Jul 18, 2012 | 11:08 PM
joem's Avatar
yes, The newer controlers should have a adapter cable that is plug and play
Old Jul 20, 2012 | 10:44 PM
sootnsmoke's Avatar
I looked everywhere in that area and do not see any plug labeled trailer. In fact, I do not see the same bundle in the photo that shovelhead posted. Attached are 2 photos under my dash. What am I missing?
Attached Thumbnails Factory brake controller connection-brakecont1.jpg   Factory brake controller connection-brakecont2.jpg
Old Jul 21, 2012 | 01:10 AM
joem's Avatar
your close, mine was taped to the bundle on the firewall side of things. Yours should be labled "electric brake" here is the link to my search last year, I found it after alot of digging.
https://www.dieseltruckresource.com/...r-t300442.html
Old Aug 26, 2012 | 08:57 PM
sootnsmoke's Avatar
Never could find it under there. Probably is there but just too blind to see it.
Old Aug 26, 2012 | 10:31 PM
SIXSLUG's Avatar
You may want to see if your truck came with the tow package.
I am not sure the trailer pre-wiring was included without it.....
Old Sep 2, 2012 | 10:12 PM
sootnsmoke's Avatar
Yes, it came with the factory tow package. Original owner bought it with that but never had a need for a controller.
Old Sep 4, 2012 | 02:11 PM
sootnsmoke's Avatar
Is that the actual plug on your truck?
Old Sep 5, 2012 | 12:23 AM
joem's Avatar
in 96' they were a blue inline flat pin, and its tucked in above the block pictured above and taped up tight
ColoRoadie
Jul 13, 2011 09:17 AM
jerky1280
Sep 10, 2005 03:34 PM
apache
Oct 27, 2004 05:18 AM
linetrash75
Oct 10, 2004 06:05 PM
dmack61
May 21, 2003 03:15 PM
