Clearance ? For Air Lift On 4x4
Old Mar 17, 2006 | 04:42 PM
PZM123's Avatar
I want to put air lift bags on the rear. I moved the two spacers from under the springs to the top. From the bottom of the rubber bumper pad bracket to the top of the axle I have 7''. Is this enough clearance for the bags ?. I called Air Lift & talked with some blonde I think, because she told me I needed 10'' of clearance for #57280 bags.
Old Mar 17, 2006 | 05:32 PM
Dorkweed's Avatar
Muted User
From: "The Peoples Republic of Illinois".....behind enemy lines
Figures the blonde would say you needed 10 inches!!!.......
Old Mar 17, 2006 | 06:56 PM
trander's Avatar
Here are the installation instructions, maybe they will help. http://airlift.r-catalog.com/ImgVD/A...5720657222.pdf
Old Mar 18, 2006 | 05:39 AM
PZM123's Avatar
Trander, Thanks for that link. Found out what I needed to know.
Old Mar 18, 2006 | 10:26 AM
trander's Avatar
You're welcome I found it useful also.
Old Mar 22, 2006 | 12:19 PM
Mopar_Mudder's Avatar
I put them on my 03 and promptly removed them. It is a very pour design in my opinion, mine would bottom out all the time.
Called airlift and they said that you had to put enough air in them to keep the rear of the truck at normal ride height all of the time. Well that is just a whole bunch too tall to get most trailers to pull level, atleast the ones I have.
If I recall you only had like 3" of travel even at normal ride height. The bags were 5" full compress and like you said only have about 7" to start with.
Old Mar 22, 2006 | 12:23 PM
trander's Avatar
Mopar_Mudder did yours bolt on the axle or on top of the springs?
Old Mar 22, 2006 | 12:31 PM
They go between the axle and spring in place of the bump stop that you take out. That is the only way they mount on 03 and newer, unless they have changed something recently.
herb
Jul 18, 2008 08:25 AM
beardedone
33
Apr 24, 2008 05:30 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
jdddually
Jun 2, 2006 10:52 AM
ccw55
Oct 20, 2003 04:49 PM
