Battery Wiring Question on older RV
I've got a 1989 22' bumper pull trailer. its an oldie, but for the most part works fine. I have been messing around with adding a second 12v batt & noticed that there are 3 wires that are supposed to be hooked up.
Qty 1 16ga positive wire
Qty 1 16ga negative wire
Qty 1 18 or 20ga positive wire
So, obviously the 2 16ga wires are for the main power to the inverter/trailer, but I was wondering what the smaller 12v + lead was for.
Anybody know? Why would there be 2 positive leads for the battery terminals.
Lar.
If you have a 2 or 3-way fridge, you would have a positive lead going to the refrigerator. As for the main power cables from the battery, I wouldn`t use anything smaller than #12 gauge. The smaller the wire, the more voltage drop you will have.
Mine is set up with 2 positive wires. The thicker one goes to the power distribution box and the seperate converter/charger.
The thinner one runs directly to the stereo, apparently to reduce "noise".
Mine is setup with 2 - 10ga. wires running from the batteries to the power distribution center to allow for 30amps of current draw. Then there are 2 - 6ga. wires that go from the batteries to the converter/charger. The convertor/charger is a 55amp model.
jukenut
Jul 6, 2009 08:43 AM
nfsommer
Oct 13, 2007 11:20 AM
bigwhitediesel
Feb 10, 2007 05:30 PM
