"Axel Flip"
Old 11-30-2010, 08:29 AM
  #31
chaikwa's Avatar
Originally Posted by MojoRising
Please spare the smart *** comments
We don't do the '***' thing here. There is no using asterisks or other symbols to substitute for letters that would make up a prohibited word. You knew this tho, because you DID read the rules when you signed up and just forgot, right?
Old 11-30-2010, 09:28 AM
  #32
CD in NM's Avatar
When I bought my MegaCab, it was about 3-4ins taller at the bed rail than my old Ford. Then I added 35" tires. I needed an additional 6"s of rail clearance to be able to pull my 5th wheel.
I went to the local metals place and bought 8"x3" box tube. I ran it from 3' to the front of the existing front shackle and then all the way back to 3' behind the rear shackle.
I attached it with a combination of welded plates on the inside and outside of the frame, and also used grade 8 bolts thru the plates. I used new shackle parts, welded them to the new frame rail. I had to change my fold down entrance step, added a step.
If I had needed more height, then I would have flipped the axle.
It cost me about $300 to do it all including the new step. Took me a couple days, working a little here and there on it, but the end result turned out good, very strong with the frame addition. I had enough new clearance that I could have used underside tool boxes for more storage capabilities.
CD
Old 11-30-2010, 11:15 AM
  #33
Jeff in TD's Avatar
I kind of thought about doing something like that, but I didn't know about how to keep the axles/wheels in alignment.
How did you deal with getting the alignment right?
PEAKSTRYDE
10-11-2007 04:20 PM
psajb
05-31-2004 08:30 AM
ox
01-20-2004 06:26 PM
JImbo1
04-09-2003 07:46 AM
moopa
13
11-06-2002 11:10 AM
Quick Reply: "Axel Flip"
