xzt+ help
Old Jan 27, 2008 | 05:48 PM
bullboy85's Avatar
xzt+ help
ok got my new modual trying to updat it but cant becuse the guy i talk to at quadzilla had me delete the driver off the computer i want to use and the updates are all skiping the install driver part so i cant put it back on this is the only comp i have to use with xp all mine are vista now. how do i get the driver back?
Old Jan 27, 2008 | 05:49 PM
bullboy85's Avatar
o and i cant wait to call quadzilla tomarrow when there open i only have access to this computer on weekends
Old Jan 27, 2008 | 07:09 PM
bullboy85's Avatar
anyone? maybe the driver didnt get installed corectly so couldnt uninstall it the same way, anyone know the driver name?
Old Jan 27, 2008 | 07:17 PM
bullboy85's Avatar
ok looked through the install and did found it, now tryed to install it same as before but am still getting the same error, any computer guys on?
Old Jan 27, 2008 | 09:45 PM
Krob's Avatar
I am no computar genious but when ever i have problem i turn the comp off let it sit for a few then turn it back on. But i dont that will really help. Maybe try to just run it from Quadzillas download page instead of saving it to your comp?
Old Jan 28, 2008 | 12:22 AM
bullboy85's Avatar
tryed them both, didnt work called them they told me it was the box after trying a bunch of different things, finaly got the new box truck runs better maybe new tunes??? still cant download any tunes
Old Jan 28, 2008 | 08:23 AM
GFB's Avatar
GFB
I downloaded all the versions of the .net framework along with accompanying updates from microsoft and that seemed to help my downloading problems.
Old Jan 28, 2008 | 12:19 PM
bullboy85's Avatar
ok ill try that next time i can get on that computer
Old Jan 31, 2008 | 10:01 PM
turbomike's Avatar
What was the error message you were getting on the XP computer ? If you click or double click on one of the files you download from Quadzilla, like the XZT+_2002.exe file, does the little X2 Public Flasher window open up ? If you click on Get Information from Module, then connect the USB cable to the XZT+ module, does it find the module and display the info: Model name, SN... ?
Old Jan 31, 2008 | 10:45 PM
bullboy85's Avatar
no it comes up with a continue or quit option, and sad it was expecting some module but got "CAN" module, on the statous screen
Old Feb 1, 2008 | 08:49 AM
GFB's Avatar
GFB
I get that sometimes too. I click "continue" and usually on the third or forth try it will eventually load the tune. It's weird and almost seems completely random, but eventually I get it to work. Both my computers do this, but if I try to load it on my computer at work it works fine every time.
Old Feb 1, 2008 | 12:33 PM
bullboy85's Avatar
ok got myself infornt of an xp, the errror im getting says "Microsoft .NET Framework" at the top then "An unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. if you click Quit, the application will be shut down immediately" "Object reference not set to an instance of an object." tryed it 20 times no luck. on the phone with teck but on hold and have been for a little over 30 mins now.
Old Feb 1, 2008 | 02:34 PM
bullboy85's Avatar
well this is great, iv now stumped the quad techs
sCreamin400
Nov 2, 2008 01:46 PM
tristan21
14
Mar 26, 2007 11:57 PM
lwcmattlifter
Jan 6, 2007 01:55 PM
superT
Apr 26, 2006 10:07 PM
marc03
Dec 29, 2005 02:05 PM
