Xzt And Egt's Help!
Xzt And Egt's Help!
I just installed my quad xzt towing box. It runs great but my egt's are to high for me. 900@70 0-80 wot 1450-1500.
marc
those numbers are alittle high i think. i have the zxt on my truck and i see 650-750 at 70. wot it can get pretty hot but not 1500. the hottest i ever saw was about 1450 at over 100 mph. i wouldn't jump to conclusions about something being wrong with the box cause every truck's alittle different. but call quad just to ask if they think it's faulty.
how long does it take to cool down to 300? mine takes about a minute to cool down to roughly 325-350 when i shut it down.
i did the tone ring mod on mine, which adds alittle pump timing, this would help in decreasing your egts.
Went for another drive. About 750-850 @70 on flat ground. hit about 1400 at about 90mph 0-80 about 1300-1350.only takes anout a minute to cool down for shut off 350 .
I haven't seen my EGTs go over 1200 degrees since installing the new turbo, except when I'm ******* it on hills. My cruising temps increased though with the larger turbo from 650 to 750 degrees at 75 mph. All temps reflecting the race version setting.
Extending the length of the dowl pin hole on the ring behind the harmonic balacer thus advancing the timing. It can also be accomplished by buying a new adjustable crankshaft position sensor from rokktech for $70.
sCreamin400
11-02-2008 01:46 PM
plug ugly
16
10-01-2007 01:23 PM
Ghost Ram
06-01-2007 11:57 PM
Doe_knob
11-08-2006 12:06 PM
