what is this housing??
Re:what is this housing??
1 more
and would this be a decent up grade for my 97 215 truck? as in verses the 12cm housing? i plan on a big cam plate and maybe a set of 370s. mike
Look in the two ports where the housing bolts to the manifold ... there is a number cast in the housing ... if it's a 14 - that # is cast there ...
thanks, it appears to be a 14.
would this housing work in the 350 to 400 hp. range?? on my 97 5 speed truck. thanks mike
And, yes it will let your modified engine breath easier. You might lose a little quckness of spooling at lower rpms, but when you put the 370s in you'll get it back and then some!<br><br>Just put mine in Sunday evening, WOW! Feels like I can do 80mph in a block. ;D Another interesting side effect is that the trans now WOT shifts at about 200rpm higher (2700) than before. Maybe the TC is making higher pressure, which in turn causes later shifts? ???
ajbirken
09-06-2006 12:11 AM
95black2615
07-21-2005 09:06 PM
HOHN
12-07-2003 02:07 PM
